588,166 active members*
4,465 visitors online*
Results 1 to 4 of 4
    Dec 2004
    312
    hypertherm 65/85
    I saw your post on other forum that hypertherm is releasing new hypertherm 65 and 85..
    im wondering if hypertherm is working on the 105 verison?
    (just purchased 45 couple weeks ago..)
    Cheers
    Dan
    Jan 2008
    2247
    There is nothing currently planned for replacing the Powermax1650.....if we were working on a project it would likely be 2 to 3 years before it would be completed! The Powermax1650 is here to stay for a while!
    Jim Colt
    Dec 2004
    312
    dang.. what is the max cutting thickness for peirce on cnc wtih 85?
    Jan 2008
    2247
    The new Powermax85 is safely rated to pierce 5/8" (typical conservative, guaranteed to work Hypertherm spec). As soon as I get my hands on one of the beta build units I will hang it on my cnc in my home shop....and we'll see what it will pierce. I'm pretty sure that 3/4" will be easy. The big improvements I see are: new torch that is similar in design (but different) to the Powermax45 torch, also have a 15 degree torch (for better reach for hand cutting) and a "mini" torch for smaller cnc machines. There are fine cut consumables, as well as 45, 65 and 85 amp consumables, all using the "conical flow" technology that makes the 45 cut so well. There also is a cnc interface that offers 5 different voltage divided output ratios for easy connection to many THC (height control) systems.....and a digital readout for air pressure and current settings....the air pressure self adjusts electronically to compensate for fluctuations in input pressure as well as nozzle orifice wear. Cut speed improvements using the conical flow are amazing over the already good Powermax1000 and 1250 speeds! Here is a link to the product announcement: https://www.hypertherm.com/happening/HO_9328_SHOW2.pdf
  1. Welcome to Hypertherm!
    By jimcolt in forum Hypertherm Plasma
    Last Post: 09-02-2019, 09:46 AM
  2. HYPERTHERM Powermax45
    By tulsaturbo in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-02-2010, 06:47 PM
  3. HYpertherm HT2000
    By matttargett4 in forum Waterjet General Topics
    Last Post: 10-27-2009, 12:04 AM
  4. Hypertherm 900
    Last Post: 11-24-2008, 01:47 PM
  5. Hypertherm or not ?
    By zeoncomp in forum Waterjet General Topics
    Last Post: 10-03-2007, 04:40 AM
