603,359 active members*
4,691 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > I am curious, what is the point of "fixtures" under the Model tab?
    Jul 2011
    297
    they can't be what I would commonly think of a fixture as Sprut insists on running my 1/2" end mill right through them...
    so if they are not for setting up a fixture (ie milling keep out area) what are they for? are they purely for decoration?
    Feb 2008
    389
    If you have it set up right SC will avoid your fixtures.
    I think there is video tutorial at SC America. I'm on the phone and I can't get you a link but if you search you will find it.
    Gerry
    Currently using SC7 Build 1.6 Rev. 64105
  1. Replies: 4
    Last Post: 05-28-2013, 09:20 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. "Floating" Y axis with fixtures...ARGH!!
    By FFWD in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2012, 10:30 PM
  4. "Floating" Y axis with fixtures...ARGHH!!
    By FFWD in forum MetalWork Discussion
    Last Post: 11-16-2012, 02:10 PM
  5. cant cut a circle? "current point same as end point of arc"
    By maccrazy2 in forum DeskCNC Controller Board
    Last Post: 02-14-2012, 07:15 AM
