588,127 active members*
5,185 visitors online*
Results 1 to 6 of 6
    Apr 2003
    598
    I-Beam construction
    There is a construction site about a mile from me, which is building a very large steel building. They have some short "offcuts" of some very large (1' across, 4-6' long) steel I-Beams.
    Has anyone built a machine from I-beams? It seems like it'd be a very stiff way to build a machine, and if aligned like an "H" it would provide 2 heavy duty rails that, presumably, would be reasonably parallel to each other.
    Seems like a good starting point to me!
    Just looking for ideas -- some brainstorming. Post away...I want to see it, no matter how off-the-wall your idea really is!
    -- Chuck Knight
    Mar 2003
    507
    CK, I am in the planning stages of building a drilling machine. The client wants a machine that can drill dia 20mm holes in a dia 50mm stainless steel pipe. Some of the pipes are a couple of meters long. I'm thinking in the same line as you to make a frame from I-beam (about 4" x 2") and then make a bridge where i can mount the pillar of the drill.
    The only big obstacle is to get the two rails (beams) 100% parrallel.....
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Mar 2003
    2139
    I beams are designed to be ridgid for bearing a load horizontally or vertically, but not good for applications where they would be subject to twist. They would be great for a base.
    Eric
    I wish it wouldn't crash.
    Apr 2003
    598
    Well, at a certain scale, the i-beams are capable of withstanding quite a bit of force in any direction. The ones being thrown out by the construction site are HUGE...a foot across, the good part of a foot "tall", and 4 or 5 feet long. Pretty stout stuff. Looking at it a different way, they're extrusions, but appear to be made from 1/4" - 1/2" thick material. Just a guess, as I haven't gone and taken a look, yet...they may very well be even heavier!
    You can imagine why I got so suddenly interested...
    I wonder if it'd be practical to lap (is that the right term?) the two rails, till they were flat relative to one another? I wonder how flat they are to start with?
    So much potential, and so many details to be worked out... MORE POSTS! Let's get brainstorming, guys! This could be a cheap and very effective way to build these things, if my guess is right...but as always, the devil is in the details.
    -- Chuck Knight
    May 2003
    26
    A piece of 12" I beam is probably at least 3/4" thick and probably a couple hundred pounds at 6' in length. Unless it is formed, (1/8" sheet)but I have never seen the stamped and formed sheets ending up in an "H" shape. Keep us posted though, as I have been wrong before!
    JD
    Please Note: No trees were destroyed in the sending of this
    contaminant free message.
    We do concede, a signicant number of electrons may have been
    severely inconvenienced!
    Mar 2003
    507
    I think I-beams are relatively straight. How straight do you want to lap the i-beams? You'll find someone with the right equipment to machine or even surface grind it 100% straight, but it would cost money (lots!).
    The other thing i have experienced in the past is that when you order material (especially long pieces) and the supplier manhandles it a bit rough it ends up bent at your doorstep.....
    When i get to the project i'm planning i would rather bolt the frame together than weld it....
    Klox
    *** KloX ***
  1. 80/20 Specs - Lathe Construction
    By Deviant in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 04-06-2005, 04:27 AM
  2. Beam deflection using stainless tubing
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-16-2005, 10:26 PM
  3. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  4. Formula for deflection of beam
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2004, 01:14 AM
  5. construction plans
    By owhite in forum DIY CNC Router Table Machines
    Last Post: 01-19-2004, 05:07 PM
