603,405 active members*
3,108 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > I.C engine question
Results 1 to 4 of 4
    Mar 2003
    6855
    I.C engine question
    What do you guy's do with you I.C engine's, do you put them in a R/C plane, car or boat? Or are they just for show and a occasional run?
    May 2003
    18
    all of the above
    over-ride untill it shatters, then back off 5% :wee:
    Cannon_Man Guest
    IC engines
    Most IC engines are mounted on some type of display board or box containing batterys, ignition systems, and other things needed to make it run. So idealy it is a self contained display piece. Of course the fun is in building them! ! ! You can see tons of photos and Cabin Fever's website: http://www.cabinfeverexpo.com/
    Here is a picture of a vaccum engine I took to the Jan. 2003 Cabin Fever Show.
    Cannon_Man Guest
    Had to re-size the pic.................
  1. The Most Powerful Diesel Engine in the World!
    By WallCrawler in forum Community Club House
    Last Post: 07-25-2010, 07:50 PM
  2. New radial engine project concept
    By Swede in forum I.C. Engines
    Last Post: 06-20-2009, 07:27 PM
  3. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  4. Anyone build a 4-stroke I.C engine?
    By cncadmin in forum I.C. Engines
    Last Post: 03-14-2004, 09:55 PM
  5. 4 stroke engine: castings & plans
    By motordude in forum I.C. Engines
    Last Post: 03-02-2004, 05:08 PM
