originaly the machine was runing a program,sudenly the machine go to fault and stop everyting
now i cant move nothing,and appears x,y,z,amp fault.....what can i do?
Did you try resetting the Heater switch in the control cabinet. It is Black with a square White button near the Amplifiers. sometimes there is two and sometimes there is one in the back control cabinet
yes i do,and change the solid state relay too,the bridge of diodes is ok,becouse the amps dont have voltaje (165 vdc)
i put a jumper on k2 to the control line #8 and they turn on,but no make any movement...make a coment...
Check all the wired in and out of the control boards. Don't just look. Physically removed them, clean them, and plug them back in. Good luck
