I'm pretty new at this and I need to circular interpolate an 11/16s diameter boss on a small eccentric shaft. It will be .250 high when it's done. I have gotten it to graph on a haas TM1, and it does run, but it doesn't look like it is doing what I need it to do. The teacher of this class isn't much help, and I need to finish this today. If anyone can get back to me asap I'd really appreciate it.
I really only need one block of it to be right, then I can make the rest the same just with a different depth for it to feed down. Go easy on me guys.. lol
O04401 (part 44 side 1)
T1 M06 (LOAD ENDMILL)
G90 G54 G41 (ABS OFFSET CC ON LEFT)
G43 H01 (TOOL LENGTH TOOL#1)
M03 S300 (SPINDLE ON 300 RPM)
G00 X0 Y0 (RAPID TO ORIGIN)
G00 X2.0 Y0 (RAPID TO PT#1)
G00 Z0.1 (RAPID TO R-PLANE)
M08 (COOLANT ON)
G01 z-.050 D01 f4.0 (feed down .050)
G01 x.3438 f4.0 (move over to edge of circle)
G02 I.3438 J0.0 (circle clockwise)
G01 x2.0 (clear part)
G01 z-.1 D01 f4.0 (feed down .1)
G01 z-.15 D01 f4.0 (feed down .15")
G01 z-.2 D01 f4.0 (feed down .2)
G01 z-.25 D01 f4.0 (feed down 1/4")
G00 Z1 m09
G40
Z0 M05
M30
