603,900 active members*
2,617 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > I could REALLY use a sample EIA-ISO program for my Mazatrol Cam T-2!
Results 1 to 7 of 7
    Oct 2007
    31
    Thanks for any help in advance guys.....the dilemma I have is that I need to shift from the typical Mazatrol programming we normally use on this machine to the EIA-ISO format for a specific job. I use Feature-Cam and have generated my shapes and output NC code. First of all, FeatureCam comes with many post-processors so choosing the correct one may be my issue. I've had no issues sending EIA programs to the Mazak, they just won't fully run. The program below upon Cycle Start will change to the proper tool then just sits there. I just don't know what this machine needs. Are there parameter settings I need to change when shifting from Mazatrol to EIA? Also, is the Z axis the same direction in Mazatrol as it is in EIA/ G-code? Sorry to bombard you guys with all the questions but I'm beginning to exhaust my options. Here's the code I've sent to the Mazak.......
    O1234
    N02G50S1200
    T0202M41
    G97S1200M3
    G0X-2.7Z0.1M8
    G96S1200
    G04U2.
    G95G1Z-0.0002F0.015
    X-2.5
    G3X-1.4Z-0.2746R2.7479
    X0.Z-0.4R2.073
    G1X0.1737Z-0.3504
    G0X-2.7Z0.1312
    X-2.557
    G96S1600M42
    Z0.2464
    Z0.1151
    Z0.1312
    M5
    X5.6974Z-8.9707M9
    T0200
    M01
    M30
    Thank you!!!!!!!!!!
    Mar 2005
    988
    Can't help you much (don't do much lathes) with a T2 control since I can't remember the last time I saw one but it might be helpful for us is you mentioned what machine model this is on and any other options (sub spindle, live tool, etc). Your spindle probably starts but it won't move beyond that? If I'm thinking right, M41 is a low speed gear select isn't it? Maybe S1200 is out of that range?
    It's just a part..... cutter still goes round and round....
    Oct 2007
    31
    Psychomill....thanks for the reply and YES that M41 does call for low gear. That MAY be it. The spindle does NOT start which is why I think you're correct. I'll try that. Since my post this morning, I've run quite a few different post processors on this program. Alot to try, that's for sure. The machine is a Mazatrol CAM T-2 with no sub spindle or live tool. Thanks again!!
    Oct 2007
    31
    Different post processor with the M41 remaining and the program now starts except it tries to return past (it looks like it anyway) home and then gives me a stored stroke error. That's where I am currently....1:15 7-7-09
    Oct 2007
    31
    It looks like the machine is trying to use the home position as X 0, Z 0 and trying to run from there. I'm unsure how to offset these values or what code to insert that allows an offset to be added. Anyone?
    Oct 2007
    31
    G53 solved that issue........moving forward...
    Re: I could REALLY use a sample EIA-ISO program for my Mazatrol Cam T-2!
    we have Mazatrol 640T, we also use Feature CAM, but we can not using our subspindle when we post the G-Code from Feature CAM, if there is because we don't have EIA-ISO activation code for the Mazak (if there is some kind of these codes?), or may be there is different in codes generated from feature cam than Mazatrol 640T for the subspindle, or some parameters out of range. I think our problem in EIA-ISO, some body have any idea.
    and how to shifting from Mazatrol to EIA, what is the Parameter setting need to be changed.
    thanks very much
  1. Sample program
    By BoKo in forum Colchester Tornado lathes
    Last Post: 10-11-2010, 08:49 AM
  2. Native Mazatrol Sample files
    By CAMFUN in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2009, 08:05 PM
  3. need sample program
    By vintageracer in forum Milltronics
    Last Post: 11-15-2008, 10:58 PM
  4. mazatrol subspindle program sample
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-30-2008, 08:09 PM
  5. Need IEI-ISO sample program for Mazatrol 640 T
    By turkaygeyik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2007, 03:03 PM
