I'll come by and haul that old piece of junk off for you.
Years ago I got my Logan for $100 along with a bunch of tooling and he delivered it. The only thing is that it had a 3 phase motor on it, it still does, motor conversions are easy. The only thing that needed immediate attention was that it needed new motor housing bushings, easy to replace. Cleaned it up, greased it and put it to work. It has a minor runout on the spindle of 2 ten-thousandths of an inch. Not bad for something that was manufactured in 1934. The previous owner made parts on it for McDonnell-Douglas. The serial number should be stamped on the ways, right side of the bed. Call Logan with it and they can tell you who the original owner was and when it was built.
Definitely go for it, run don't walk or I'll be right behind you. Just remember that they are top heavy and like to tip over when transported, even after you've taken the legs off. I speak from experience, mine rolled over toward me after taking the legs off while on the floor. I went to catch it, to keep the feed levers from getting broke off and got my arm pinned under it. OUCH My arm was sore for a couple of weeks, BUT nothing got broke. Thats all that matters, right.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
