HI, I'm building My first cnc router, 3 axis, and i have a cuestion, i've created mi oun steppers controller for the paralel port an it works very well but for now onli with Kcam soft, this sot let you setup the pinouts and evrithing to use the LTP port but in not a realy good soft.
Wich software do you use for the DIY cachines?
OK, I have problems with the english because i speak spanish so, I gonna write again in spanish, just in case.
hola, disculpen las molestias, me estoy abricando mi propia router cnc, me arme mi controladora de motores paso a paso de forma casera con un poco de investigacion en la red, sirve atravez del puerto apralelo y la verdad es que funciona muy bien, el problema que tengo es que solo la pude configurar con Kcam que es un soft bastante feo, que sofeare usan para sus maquinas cnc homemade?
gracias
thanks
