587,997 active members*
2,124 visitors online*
Results 1 to 7 of 7
    Feb 2012
    87
    Question I have a problem in Z axis flexing
    I have had this problem since I got the machine and I would like to know what is the solution to this.
    Please watch the video, thanks
    Aug 2015
    142
    Re: I have a problem in Z axis flexing
    That is normal , the flex depend on machine rigidity ,on rails used, if they were rolers then u wouldnt have this flex , but with balls u have flex , and that depend and with machine base rigidity and weight of the machine , u cant get a high rigidity with a low weight machine , u need iron cast and high mass dapening weight in order not to flex that much .
    Feb 2012
    87
    Andreiir I appreciate your reply, if my machine has linear guides and I was thinking maybe I would have to tighten a screw, but I have not because I consider myself very new.
    I've also been thinking about swapping out the spindle motor for a stiffer one, do you think that can reduce flex?
    my machine is not small because its weight is around a 1 ton
    Aug 2015
    142
    I see that ur support of motor stays on a thick aluminium plate u need to be shure that the motor support stays near cariages of axis for beast rigidity , a plate of aluminium without any lateral support will flex too .
    on a cnc machine u need to see what is the weak point that flexes more and there u need to improve the stiffness .
    Aug 2015
    142
    About the motor i think u need a motor that suits ur needs , for milling aluminium u need high rpm and not big hp , a 2.2kw will work fine , but if u want to go on steel u need a low rpm and high torque .
    Feb 2012
    87
    Quote Originally Posted by Andreiir View Post
    I'm sure the bracket is cast iron, but I'm going to use a magnet to check.
    Regarding the carriages, I have recorded a new video where you can see the measurements and their maximum route:
    Feb 2012
    87
    I have also done a new flex test to the rail guide and base plate
    I would like to know your opinion and that of other experts to understand more about cnc machines and solve problems. Thanks
  1. X axis flexing while milling
    By johntech in forum Automation Technology Products
    Last Post: 03-11-2015, 09:21 AM
  2. X Axis flexing while milling
    By johntech in forum Chinese Machines
    Last Post: 02-07-2014, 01:50 PM
  3. 20mm Shafts flexing
    By peterm in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 01:31 AM
  4. VF-10 Table Flexing
    By MICFDI in forum Haas Mills
    Last Post: 06-14-2011, 04:34 AM
  5. How long before flexing for Acme 1/2-10?
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 11-08-2005, 11:14 PM
