I lost mashine parameter biesse rover 316 could anyone help me?
firstly find out why?
is the memory backup battery dead? see picture attatched.
is the control a 480/481?
anyone else that has an old biesse: these are getting old now. change the battery before you lose the memory too
(put the new battery on in parallel first, before removing old battery. that way you wont lose memory while changing it!)
its located on inside of controller frame.
use long wires like the original so when corosion starts it has a long way to go before getting to the circuit boards. (dreaded blackwire corrosion is a killer of chips)
so much to learn, so much to pass on.
Where that battery is? But with battery every think is ok i think. I lost parameters because machine stooped work. And i reinstall program from floppy.
I do not know is every parameters are correct now.
Now when i want to start bore program i got felt i0101 that meaning: Routine bzw. Festzyklus fehlt
io101 is wrong tool config
is your program calling head config 1 but machine is set to 2 etc?
hc1 or hc2 etc
all drills must be set up correctly in config.
you must also call a tool change for the first part of a program otherwise machine doesnt know what tool its to use.
optimization program generating machine code and selecting tools his own discretion. maybe optimization program selecting wrong tools. i dont know. i will try to select different tool without optimization.
I change tool but I got same error.
I'm trying to configure tools but I do not know how exactly to configure. I found list config 1, config 2 ant etc. and optimization 1, 2 etc i trying various configuration but machine do not work.
Maybe you can help to config drills correctly?
I lost machine parameter biesse rover 316 NC 481 controller after battery crashed and unsuccessful reinstalling. Maybe anyone have boot disk with all data?
do you have machine control manual?
it shows how to configure tools
did you contact biesse uk?
yes i have manual.
i contacted with biesse uk they suggested nearly subsidiary.
they sent parameter disk. i will try it when i replace new battery. with old battery program not working.
Hy !!!
I have same problem with Rover 322 (CNI 481 controller) !!!
But i lost everything,C and D(eeprom) its empty.......first window when maschine start its disappeared (first window where its global zeroing button,coordinates......)
sory for bad english !!!
Can anyone help me please ???
mar 404
did you get yours up and running ok ? where did you get parameter disk from? uk or other?
