Hi I am looking for a post processer for a puma 2500sy if there is anyone out there that is using feature cam to program there 2500sy you could make my day.
Does anyone know which cad/cam software works best for a 2500SY
cheers phill
cheers phill
Hello ,
I'm currently trying to write a post for a Puma 2500Y
I'll let you know when I've finished.
Mark
Nice one,
I will look forward to hearing from you. Are you using the xbuild to do this?
I have managed to buid a post that I can use for turning but does not yet work for milling on the lathe.
If you're a current subscriber or on maintenance ask tech support they'll make one for you.
Hey why don't you guy's try to modify a Puma 20021TBX or an Deawoo 2000SY ? How close are these?
I would think the 2000SY Daewoo would probably get you you real close write out of the box? You shouldn't need to many changes if any to at least generate every day programs.
Hey there Big Daddy, if you have a post for a Puma 2000SY that would be the same as the one for the 2500SY.
If you could send it to me then my email address is [email protected]
Thanks for replying.
