587,180 active members*
4,679 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > I need help engraving letters
Results 1 to 9 of 9
    Aug 2008
    5
    :drowning:
    Hello every body hope someone can help. I'm learning cad on my own , I use bobcad-cam V21. I'm trying to learn how to engrave useing a v bit I wan't to use cutter height to change the width of my letters smoothly. were the ends are thinner and the middles are wider and deeper I think its called "ramping" to engrave fancier fonts. I'm trying to learn the proper terms for the operations ,you guys (and girls ?) are my teachers, I hope my question makes sense. Thanks
    cutter22
    Mar 2003
    4826
    What kind of contraction is "wan't" anyways? Always wanted to know
    You are looking at some serious machining to do that. Sounds more like what V-carve might do for you than Bobcad.
    First you get good, then you get fast. Then grouchiness sets in.
    Aug 2007
    339
    Red face
    All you need really is the proper software and it is Magic. I use Alphacam and engraving comes with the software. It does the ramping in and out to give better detail. If you try to do this with out the proper software you may not live long enough to get it done, because it is 3 axis moves. Unless you grew up on G code you will have a lot of problems.
    Aug 2008
    5
    definition of wan't
    wan't means - I used proper punctuation BEFORE I started teaching myself CAD, CAM, and CNC
    Thanks for the help
    Jun 2005
    1436
    I hesitate to add my experience to this thread, but I have just done this using a supposedly 2.5D program, with extremely limited G code functionality(ugh!).
    I drew a Times Roman letter A in corel draw, overlaid a fine grid, and used that to give me the line and widths of various key points, like the serifs.
    I then used an Open Office spreadsheet to calculate the z depths at every 5 degrees around the curves, and used these figures to build up the profile of sloping, straight line cuts that is all my software allows.
    And it worked.
    I don't recommend this as a method, but I learnt a lot doing it.
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
    Apr 2007
    327
    Quote Originally Posted by greybeard View Post
    And it worked.
    John
    Or, you could just by Vcarve and have it done for you. although if you are getting paid by the hour, your method is perfect!
    Mar 2007
    thank you
    Feb 2008
    21
    V-Carve Text.
    This is my first post!
    I have built my own CNC router 5' in X, 8' in Y and 6" in Z. It is runnign great but like everyone else I used all of my money on the machine and basic software.
    Due to this I had to develop my own V-Carve data base. Take a look on Ebay and search under VCarve Text and CNC Router.
    I actually figured out a way to develop the 3D contours needed to drive a 90° V tool that can make the carved letters just like the fancy programs without the cost.
    It is all arc, line and spline geometery that can be scaled, copied and moved just like any other geometery in a CAD or CAM program. The end result is great and it is very fast.
    Please E-mail me at [email protected] and I would be happy to give any additional information. I will also send a sample text letter A so you can test it with your system.
    Thanks!
    Nils[email protected]
    Jun 2005
    1436
    Hi Nils, and welcome to the madhouse
    I may well pm you for details, but for general info, what type of software/controller are you using ?
    As you will see in my post, mine is extremely limited, and like so many others, funds are too limited to buy my way out of every problem that turns up.
    So I hope my contribution is that for some of us, ingenuity can be an alternative route, and can be rewarding in other ways.
    Regards
    John
  1. Pocketing around letters ?
    By SScnc in forum Mastercam
    Last Post: 12-17-2008, 02:41 PM
  2. Raised Letters
    By Astroguy in forum Mach Mill
    Last Post: 09-12-2007, 01:42 AM
  3. Trying to chamfer some letters
    By justCNCit in forum Rhino 3D
    Last Post: 02-08-2007, 09:41 AM
  4. AutoCad letters...
    By WilliamD in forum Autodesk
    Last Post: 10-18-2006, 07:47 PM
  5. Software to cut out letters
    By esmiller in forum Commercial CNC Wood Routers
    Last Post: 12-29-2005, 01:42 PM
