603,333 active members*
3,393 visitors online*
Results 1 to 5 of 5
    Oct 2006
    8
    I need help for this file work with Mach3
    I have TurbNest2 work with Mach3.
    when start Mach3 first one and load the file Newla18.cnc it work very slow and load the file Newla5555 it work very good and load the file Newla18 work is good
    pleas comment urgent how i can fix this problem
    Newla
    Attached Files Attached Files
    Mar 2003
    35494
    I don't understand what you mean, but it looks like it might be the lines G42K2.SHould be either:
    G42Dx where x is the tool number, or
    G42Px.xx where x is the tool radius.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2006
    8
    Dear Mr. Gerry
    Thank you for your comment
    The first one please open the Mach3 and load the file Newla18.txt look the speed is very slow than load the file Newla555.txt you find the speed is good and work very nice
    load egan the file Newla18.txt work is very nice
    pleas comment
    Mar 2003
    35494
    The first one has no Feedrate, so it runs at the default feedrate. The second one sets the feedrate at 2500 (F2500). When you rerun the first one, the feedrate is now set at 2500, so it goes faster. Just add F2500 to the start of the first program.
    Gerry
    Oct 2006
    8
    Dear Mr. Gerry
    Thank you. Now is good
    Ahmed
  1. Mach3 Plugin Tutorial and Prototype File Set
    By jemmyell in forum Mach Wizards, Macros, & Addons
    Last Post: 11-26-2007, 05:30 PM
  2. Mach3 won't cut this file smoothly
    By Salty72 in forum Machines running Mach Software
    Last Post: 11-22-2007, 02:17 AM
  3. Mach3 shape file to ACAD
    By vmax549 in forum Autodesk
    Last Post: 11-20-2007, 07:23 PM
  4. Mach3 / Bobcad V21 file help
    By Dfennell in forum Mach Mill
    Last Post: 03-25-2007, 06:48 PM
  5. Mach3 xml file
    By Ed Williams in forum Mach Mill
    Last Post: 04-08-2006, 01:50 AM
