587,172 active members*
3,349 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > I need ideas for new tutorials.
Results 1 to 17 of 17
    Mar 2009
    50
    Talking I need ideas for new tutorials.
    Hello everyone in the SprutCAM forum. If you have any ideas for some tutorials that you would like, or that you think would help new users, let me know. The first 2o tutorials I have made are available on our website at
    http://www.tormach.com/videos_cadcam.html
    I want to begin on the next 20 soon so I need some fresh ideas.
    Jul 2004
    595
    Id love to see some more 4th axis tutorials. Especially using the new available features. Machining organic shapes, such as statues etc.
    David
    Jan 2006
    46
    How about one showing how to use the mill as a 'vertical lathe'?
    Dave.
    Hello
    I am Glenn from Shang Hai China.I am a design engineer in electronics field.welcome to all friends communication with me
    Jun 2006
    340
    Tutorial topics
    Hi Eric,
    I think new users and others would benefit from tutorials on:
    Workpiece - manipulating the workpiece, such as importing a model for the workpiece; adding stock to surfaces; changing the auto workpieces.
    Functions under the Model tab - the seven functions from Intersect to Triangulate.
    Suitable tasks for machining options - for each of the options, give examples of the type of tasks they are suited for; eg, 2D profiling is good for chamfering. Also perhaps comments on the tasks that an option is not suited for.
    Bevin
    Aug 2005
    86
    How about XML tweeks to undo default setting (V2007 and V7);
    - 3 deg draft angle set to 0
    - change trochoid to off
    - safe level as default
    - change Smart cut feed values
    ...answer the phone ...make coffee
    Mar 2009
    14
    I have seen many examples of machining the "top" of a part. I have seen one example of machining the "sides" of a part.
    For example, I would like to machine a Picantinny Rail (described on Wikipedia) without removing the part from the vise (to improve the accuracy). I would need to machine the part on top and both side, including some areas that are under an "overhang".
    Can SprutCAM help with this kind of machining?
    Larry
    Jun 2006
    3063
    I'd really like to see tutorials that go through a particular machining operation (say roughing waterline) and explain all the settings on the parameters screen. It would be especially nice to have a description of when an option should be used and when it should not be used (e.g. trochoidal).
    Mike
    Mar 2010
    There is a ton of tutorials on the SprutCam forum. For $25 you can get access for a month then download them all. All very good tutorials.
    That being said. I would love to see something like mentioned above on how to machine around fixtures and perhaps how to machine and use tabs or dropping parts.
    Apr 2008
    59
    Quote Originally Posted by davebaldwin View Post
    Dave.
    +1
    I'd be interested in a quick walk-through of that as well.
    111011 101101 101001
    Jul 2005
    340
    I wish to see a tutorial with a part machined from different sites , not an 4th axis project , a normal part machined in a vise in few setups : top , bottom , left and right in one SprutCAM file , generating NC codes for each setup , making adjustments.
    4th axis flat part
    I'd like to see milling grooves, pockets and drilling a flat sided part using the 4th axis. Like a zig zag pattern that requires the 4th to rotate while machining.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Jul 2006
    28
    Quote Originally Posted by Eric_Tormach View Post
    i would like to see a tutorial on machining die surfaces (3d) and mold cavities.
    Jan 2007
    1332
    Quote Originally Posted by MichaelHenry View Post
    Mike
    I second Mike's thinking here. I would like to see more tutorials explaining the basics of using SprutCAM like settings on the parameter screen.
    Don
    Apr 2008
    59
    Quote Originally Posted by Don Clement View Post
    Don
    I'll jump on this bandwagon as well. There are a few things I do just because I know it works correctly when I do it that way but without understanding why.
    Mar 2010
    Don
    +1 I have trouble defining speeds/feeds in most commands. Normally going through the tutorials they just click on the settings without explanation.
  17. #17
    Nov 2005
    145
    I think a good one would be to use the new Rotary Machining (finishing) operation in SC7 to machine a simple cam with multiple passes. - Terry
  1. Tutorials
    By pauls in forum Tutorials
    Last Post: 02-22-2011, 02:55 PM
  2. tutorials
    By elc in forum SprutCAM
    Last Post: 05-19-2010, 07:41 PM
  3. Need Tutorials
    By White Rabbit in forum Uncategorised CAM Discussion
    Last Post: 03-13-2009, 07:34 AM
  4. Tutorials
    By Buried in forum Rhino 3D
    Last Post: 06-07-2004, 06:17 PM
  5. cnc cad tutorials
    By WOODKNACK in forum Uncategorised CAM Discussion
    Last Post: 06-02-2003, 07:33 PM
