603,341 active members*
5,757 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > North America RFQ's > I need one small piece made from 1/4" thick mild steel plate
    May 2012
    7
    It is just an 0.25" thick, 3.5" × 3.5" square with a single shape cut out of the middle of it, like this:
    I have a CAD file (.DWG) for it that has been used before to make that piece, but I need another piece made. Also, I want the cuts to be at least as smooth as the surface of the steel already is from the mill. With the one I had made several years ago, the dimensions were fine but the cut edges had little striations in them, like this:
    Dec 2023
    Re: I need one small piece made from 1/4" thick mild steel plate
    Company website: http://www.figo-model.com/
    WhatsApp : +8613428951099
    E-mail: [email protected]
    May 2012
    7
    I found someone to make the piece for me so this RFQ is closed.
