603,874 active members*
4,442 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > I need someone who can scan parts to cad
Results 1 to 8 of 8
    Mar 2007
    125
    I custom manufacture a remote control turbine jet. There are a few parts that I make from wood that I have been scribing a template, cutting out the wood, to make the part.
    I currently have access to a laser cutter for a lot of parts, and I own a Tormach CNC machine.
    There are such complex shapes to some of these "formers" that I have never been able to draw it quite right.
    Does anyone here have the capability to touch probe or scan to cad a piece of 1/8" light plywood approx dimensions 10 inches wide by 5 inches high?
    Thanks in advance, I can be emailed at [email protected]
    Feb 2006
    174
    Hey Sean,
    Can't you just put the former on a flatbed scanner, import the image to a Cad program, and then trace over it?
    Lars
    Mar 2007
    125
    Tried that multiple times, for whatever reason, it never scans 1:1. Tried two different scanners, every color imaginable.
    I was hoping someone in here had done this before and figure out a way to do it accurately. If not, anyone with a touch probe, I'd be willing to pay for the service if they can get it done right. I'm tired of sanding these particular pieces by hand, when so many of what I do is CNC'd or laser accurate.
    Jul 2006
    117
    I've always gotten one to one on my scans. I then use BobArt to vectorize and get good results. Instead of hand sanding, modify the artwork until the program will cut it right.
    GeneK
    Mar 2007
    125
    Hey Gene, I use Bobcad as well, and I was not able to make it work. Would you be willing to take on the task? This is an area of talent, that I do not have.... I'm willing to pay someone for their expertise.
    Oct 2008
    14
    wait, you can scan parts into a CAD program? That would solve all the trouble of me having to always milling every flipping part of my heli, which is like 450.
    Feb 2007
    1084
    Quote Originally Posted by LN-JET View Post
    Hey Sean,
    Lars
    Quote Originally Posted by seanreit View Post
    I do the same thing with a flat bed scanner, and my scanner scans within 2%. What I do is take a pair of calipers, scribe 2 lines on a piece of paper and scan that with the part (pencil trace the scribe impressions if needed). Then scale your drawing accordingly. I use 6" calipers and scribe points 6" apart and can get any part from my scanner to CAD to machined within .005" of the sketch or part that I scanned.
    Good luck.
    Oct 2005
    1237
    usually the problem is setting up the scan. If your CAD or Vectorizing program opens at 300 PPI, then that is what you scan at. Often times when I've had problems like you mention it is that the picture/item was scanned at a differing PPI/DPI (pixle per inch/dot per inch) than whamy program was opening the file at.
    I've scanned a Harley front brake lever, then opened in PhotoShop, then AutoCAD and reverse engineered the pivot locations. I had a problem like yours and it all boiled down to scanning resolution.
  1. CMM point scan to SmartCAM
    By lallen in forum Uncategorised CAM Discussion
    Last Post: 06-12-2008, 01:26 PM
  2. importing large scan into v21
    By gromit68 in forum BobCad-Cam
    Last Post: 07-05-2007, 08:47 AM
  3. Scan to G-code
    By 9lrac9 in forum Mach Software (ArtSoft software)
    Last Post: 06-23-2007, 03:41 AM
  4. Model or Scan?
    By robinsoncr in forum Rhino 3D
    Last Post: 02-27-2007, 04:54 PM
  5. Scan-Import Shapes
    By edwardpic in forum Waterjet General Topics
    Last Post: 10-04-2006, 05:41 PM
