603,861 active members*
4,231 visitors online*
IndustryArena Forum > CAD Software > Autodesk > I need true radius solids??
Results 1 to 7 of 7
    Jan 2013
    11
    How can I get .DXF solids to export with out faceting ?
    Mar 2003
    35494
    Are you using AutoCAD?
    What version?
    What version dxf?
    What are you opening them with that shows them as faceted?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2007
    1795
    in dxf, solids are there.. however they are in a format that readable for autodesk programs..
    what you see they are submeshes.. for other programs..
    so getting out from dxf a solidmodel, you need autocad..
    your other way using acis, iges format..
    some other program, like rhino, bobcad and i think solidworks too, reading directly autocad files.. so that could be another way..
    Jan 2013
    11
    i'm using Auto 2009... exporting from a .DXF solid into a .STL file and opening in Meshcam trial version.... I use Auto cad and am trying to figure out an option for an afordable 2.5/3 axis software for my Fadel VMC....
    Mar 2003
    35494
    Where's the .dxf coming from?
    If it's smooth in AutoCAD, type FACETRES and enter 10 before exporting.
    Gerry
    Jan 2013
    11
    Thanks that seemed to work...
    Jan 2007
    1795
    you can try one more thing..
    open your mesh,model in hexagon, and subdivide.. can happem you get back the same smooth model..
    actually it never be same smooth.. however subdividing to smaller polys can result you get very close the geometry..
    hexagon is free on the dazstudio website....
  1. 021 start radius end radius error
    By XAD in forum Tree
    Last Post: 06-01-2012, 04:59 PM
  2. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  3. Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-10-2010, 03:16 AM
  4. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  5. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
