603,960 active members*
2,538 visitors online*
Results 1 to 5 of 5
    Sep 2006
    19
    I/O Channel Parameters
    Hey,
    Anyone know what the Fanuc 16i parameters are for the I/O Channel? Want to G10 the channel from Dataserver to Serial on the fly.
    Mar 2003
    2932
    Parameter #0020 is the I/O channel.
    Sep 2006
    19
    Thanks for the responce! I've got the Fanuc DVD, but it's not much better to navigate than the old yellow books. Do you happen to have the I/O channel specs? 5 is Dataserver, 0 is serial, I think 2 is sram card. Don't know the rest....
    Dec 2003
    24260
    This might help a bit.
    Al.
    Attached Files Attached Files
    Albert E.
    Mar 2003
    2932
    This is from the 16i Parameter Manual.
  1. Cutting in channel
    By WEDM in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-18-2008, 05:17 PM
  2. What bit to use to drill C channel?
    By teamtexas in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2007, 05:58 PM
  3. 80/20 versus u-channel
    By SteveT44 in forum DIY CNC Router Table Machines
    Last Post: 11-19-2005, 11:39 PM
  4. IRC channel for EMC
    By Dan Falck in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2004, 06:03 PM
  5. Two steppers from one channel?
    By m1911bldr in forum CNC Machine Related Electronics
    Last Post: 03-30-2004, 03:30 AM
