603,371 active members*
3,765 visitors online*
Results 1 to 17 of 17
    Dec 2006
    775
    I purchase the KL-4030, 3 stepper package
    Just want to sort of jump up and down with enthusiasm.
    I purchased the Keling CNC 3 Axis Package with 425 oz-in motor and KL-4030 Driver $389 and can report that I'm very happy with it. This is my second DIY CNC machine, but this time I wanted to double the torque. I couldn't resist the price. I liked the idea of separate modules for each motor, a BOB and I wanted a power supply too.
    John was very helpful in getting me setup. We ran into a few snags, but nothing that John couldn't help me with.
    Here are some pictures taken last night.
    With a 1/2 Acme single start lead screw, half stepping the motor, I got it to jog at 75 ips.
    I'm a couple days away from cutting my first piece of wood.
    Dave
    Jul 2004
    71
    Looks good, i am looking at the same kit as well for my x2 mill.
    Feb 2007
    632
    hi Dave.
    i am also looking at getting this kit for my x2 mill with cncbridges X-Y table. Your setup is looking great. Any chance of providing a simple sketch of the wirings and any resistor or transistor being used with the kit?
    What were the problem you had and was sorted out by keling? Thanks in advance. More pictures please.
    Alex
    Dec 2006
    775
    First of all, I have to laugh at myself. My name is Dave, I don't know why I signed as John in that first post. Never fear, I've fixed my first post.
    Anyway, regarding the wiring diagram, here's a link that should be all you need for wiring.
    Go here to see my scrappy build log. I have some pictures on post 93 and 94 of the Keling hardware.
    I'm just about finished with my build.
    Sign me
    Dave (for real)
    PS, if you happen to call Keling for help, well you will be talking to John
    Feb 2007
    632
    Hi Dave, No problem. i have edited my post as well. Thanks for the info. Hope to see the whole thing. Maybe some photos in the near future? Thanks.
    Alex
    Feb 2007
    11
    About those wirings...
    Maybe you could show some diagram of how to wire the limit/home switches? maybe some photos....
    Thanx
    Dec 2006
    775
    Hi Ferverx,
    Always remember that I'm a newbie at this stuff too. I've read a lot of posts, but what I do may not be good for you. Tonight, I'll take some pics of my RatShack micro switches.
    When you solder the switch always use the NC lugs. Thus the switch is always closed in normal operation. That's the best option for safety. If the wire breaks your machine stops. If the switch is contacted the machine stops. Either way you are safe.
    I have 4 circuits. 3 of them are Home circuits for the -x, -y and -z axis. The 4th circuit is a series circuit of +x, +y and +z switches. If any of those switches opens, then the machine stops.
    In Mach3, the software gives you the option to find the home or negative x,y&z limits of your machine. This is helpful at times.
    Look again at that schematic link. It shows how easy a limit switch is to connect.
    Dave
    Feb 2007
    11
    tnx
    Its just that I am learning...trying to figure out which product to order. I live in EU and we have some regulations that prohibit to order xylotex drives We also have 230VAC electricity not 150VAC (or "V", I really don't know), so all kits made in US are not compliant
    lots of problems...
    P.S. Where do you wire the 4th circuit - there are free 12, 13, 15 for limit switches. Are you using also 11. (numbers based on wiring diagram, you linked above).
    Dec 2006
    775
    Yes, I'm using 11, 12, 13 and 15.
    Quote Originally Posted by ferverx View Post
    tnx
    Feb 2007
    632
    Quote Originally Posted by Glidergider View Post
    Hi Ferverx,
    Dave
    Hi Dave,
    I am just curious and hope you can help me to answer this. I know what are limit switches used for, but what I don't know is what happen if you don't use a limit switch in your axis? Will the table slide off the ball screw or something like that if there isn't any switches?
    Also, I read somewhere that you need 2 limit switches for both x and Y axis and only 1 switch for the z. Is that how you set up your mill? Thanks.
    Dec 2006
    775
    Actually, right now I'm only running with three minus home switches. I do plan to add the 3 plus switches. What I risk is an unattended machine running wild. Some of these machines are so strong that they can break themselves if they run to the end. To many variables to speculate. It would be easy to design a CAD part larger then your table's bed. The software won't necessarily know that its going to exceed its bed size. The limit switches stop a runaway router.
    Feb 2007
    632
    Thanks. Glad to know that the 4030 can have limit switches attached. Where did you get the limit switches?
    IT works Great
    Hello
    Pls check this Video for Dave' system
    http://youtube.com/watch?v=vR74JnEB9Rk
    It works great
    He used KL-4030 Package
    John
    Mar 2007
    11
    Limit switches
    Quote Originally Posted by alexccmeister View Post
    I think he said he got them at Radio Shack.
    A much wittier reply came to mind immediately after I clicked the 'Send' button
    Feb 2007
    632
    Ok, miss that one. Thanks for the info.
    Dec 2006
    775
    Yes, I got them from Radio Shack. I must confess, that I don't use them. I had one instance where they incorrectly stopped the works. A stray signal noise or something. So I disconnected them. I will go back and restore them someday, however I watch my machine pretty closely and have my hand near the stop button most of the time anyway.
    I now know how to restore a stopped project in mid stream without ruining the project. That first time caused me to ruin some wood. Mach3 does a pretty good job of restoring a run in midstream. I just didn't know how to do that last month.
  17. #17
    Feb 2007
    57
    motors
    i see ya like the kit (nice motors huh!!) fast little buggers
  1. Best CAM Package for Solidworks
    By rvanbeek in forum Solidworks
    Last Post: 08-29-2014, 01:07 PM
  2. CAM Package What is availible
    By SPEEDRE in forum Autodesk
    Last Post: 09-23-2005, 01:53 AM
  3. What do you think about the Stepper world .com FET3 package
    By Sanghera in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 08:08 PM
  4. Stepper Package
    By freezer in forum DIY CNC Router Table Machines
    Last Post: 03-12-2004, 06:11 PM
  5. another package
    By Laff Riot in forum Uncategorised CAM Discussion
    Last Post: 06-07-2003, 09:28 PM
