3 steps to follow:
-load the new program
-set up all the tools and enter the length offsets
-set the first piece of stock up on the table. Use your edge finder to find the location of the stock X0Y0, which you determined by the position of your part on your CAD screen. Teach these coordinates into your control by being on the work offsets page, and pressing the cursor until the correct axis is highlighted across from the correct G5x work coordinate system, and press the "Part Zero Set". Set one axis at a time (this is how it works).
THEN, you are ready to do the graphics mode check. When everything is set up this way, then the graphics mode check will offer a valid check of tool and axis overtravel.
First you get good, then you get fast. Then grouchiness sets in.
