Ok, I like to consider myself to be fairly smart. Neither of the on-line tutorials for beginners works so I have been referencing the manual and going on my slight memory of working with older cad systems...like 10 years ago.
I've figured out how to place objects and rotate etc... that's no problem. I'm having trouble adding points after exploding and extruding an existing object.
Lets say I connected up 6 lines, I group them as one object then want to extrude them to become a 3D object .375" in depth. I can't figure out the method to do this. I've tried playing with the extrusion tool but can't get it to do anything except place an x on the screen. I also tried a different approach where I placed a box and sized it appropriately making it .375 thick but now I need to place new points in the box to change the shape then move the two points face and back in the same motion so the front and back remain the same shape.
Is there a tutorial somewhere that takes you through the basic steps on up? I'm dying here (chair)
I took a peek in the TurboCAD/CAM discussion but there ain't much going on over there.
Thanks!
