552,799 active members*
2,160 visitors online*
IndustryArena Forum > CAM Software > PTC Pro/Manufacture > ICAM 18 Post-processing
    Feb 2011
    Hello- Longtime reader of the forums…1st time poster.
    I am using Pro/E WF4.0 to create .mfg files for crankshaft machining. We are using Mazak E-650HS Multitasking centers to get the majority of the work completed and they do a good job of it for the most part.
    Currently, we are in the process of developing an ICAM18 CAM POST post-processor which will allow me to generate the majority of the code from .mfg files. Our programs are heavy on macro variable and sub-routine methods, so a complete all in one .mfg file would be tough to replicate without numerous insert and CL command statements.
    One area we are working thru is the use of G68 3d coordinate rotation while machining a simultaneous XYZBC eccentric milling sequence.
    I would be interested in learning more about different techniques some of you may have employed, what you have done to get a post which works for your needs and if you have went to the next level and married your post with ICAM's simulation/verification software Virtual Machine.
    If you have any experience with these type of issues, please reply. Thanks for your help!
    Apr 2022
    Re: ICAM 18 Post-processing
    iOS, Android Mobile App Development Company Qatar, Based Company. Award-winning apps.
    Jun 2022
    Combine pdf is fantastic software which Combine multiple pdf files into one file. You can merge,combine PDF files.With this tool you can do this work very easily and without quality loss.It is easy to merge multiple PDF files together quickly & simply.
  1. Post processing.....
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 03-22-2008, 07:43 AM
  2. Post Processing with MasterCAM
    By kzoojam2006 in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2006, 03:50 AM
  3. boss 6 post processing........
    By cnc Rookie in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2006, 07:21 AM
