603,354 active members*
2,715 visitors online*
Results 1 to 5 of 5
    Nov 2008
    10
    Idea for 4X4 hybrid
    I have been a lurker here for a month or so now and I am planning to start a build after Christmas, I give all my spare money to the grandkids at christmas time. Anyway I noticed over at www.buildyourcnc.com there is a pic of Octavio's Metal CNC Machine that I found interesting. I thought I would bring it up about the way he used the same bolt for both the Z axis and Y axis bearings. I have drawn a Sketchup of something that I would like everyone to digest. Perhaps it could be a mod for the 4x4 hybrid or something.
    Attached Thumbnails Attached Thumbnails Tims 4x4 hybrid idea 02.jpg   Tims 4x4 hybrid idea 01.jpg
    Aug 2004
    3215
    Personally, I do not like the idea of one axis Dependant on another, can cause havoc trying to diagnose and fix a problem on an axis, which can trow another one off. I like mine to work independently.
    Joe
    Apr 2005
    438
    Not sure but don't thank you would be happy in the long run.
    My Z has a small set screw on the two left v-wheels as you look at it from the front.
    This is to take out any "play" left-to-right. Same on two of the Y v-wheels to adjust the up-down. After taking out any play with the set screws you then tighten down the nuts.
    Not sure how you would be able to make the same adjustments easily on the v-wheels sharing the same axle on the z and y axis.
    Nov 2008
    10
    Yes I can see what you mean. I was just curious as to how the box that moves along the Y axis could be strengthen in some way, make it more stuff you might say. I was just thinking along the lines of making the box that gets used as the Z axis holder less part of the torsion between the Y axis and the Z axis.
    The way I see it, all the g-force from the router head travels through the Z plate then the Z bearings then all the way through the box to where its mounted to the Y axis. If the route could be shortened in some way there would be less energy passing through the Z box and as such that box could be made with less meterial. The box would be there only to hold the Z axis motor and screw. Not as part of the torsion between the Z and Y. That would also possibly increase accuracy.
    The problem of the set screw to adjust pre-set is solved by drilling a small hole in the edge of the Z plate at 45 deg. Putting a bolt in this way would put presure on the v groove bolt at 45 deg. causing both inward presure and downward presure for both Z and Y
    Aug 2004
    3215
    We use eccentric and concentric bushings for the bearings to take make the required adjustments.
    Joe
  1. Joe's CNC 4x4 Hybrid
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 04-17-2015, 09:13 PM
  2. Building a Joe 4x4 hybrid as a 2x4
    By GibbonsRock in forum Joes CNC Model 2006
    Last Post: 04-06-2009, 05:32 PM
  3. koike hybrid NC D2
    By cvafiadis in forum Waterjet General Topics
    Last Post: 10-07-2008, 04:44 PM
  4. hybrid electric
    By blackbeard52 in forum I.C. Engines
    Last Post: 03-21-2008, 02:51 PM
  5. mini-mill /bridgeport hybrid cnc idea, help
    By Sparky_NY in forum Benchtop Machines
    Last Post: 09-11-2007, 09:26 AM
