587,584 active members*
3,609 visitors online*
    Nov 2006
    303
    Ideas to fixture this part!
    I probably cannot share the drawing for this part but pretty simple. It is Titanium, blank size is 3/16 thick x 2W, x 3L. The part is mostly profiled but with some minor pocketing on both sides. No through holes. Part looks similar to a chevrolet emblem.
    I am just not sure how to fixture this. I might normally setup the first op in step jaws at full 3/16 deep, machine what I could and fixture on those features on the flip but there are no features I can really fixture on...Because this is Ti, I need a firm grip on it. I am not sure how little I can get away with in step jaws. Could I do as little as .040? That does not seem enough.
    Jul 2011
    36
    Not sure if this suggestion will suit your needs but in extreme cases I have been able to machine thin parts (mainly in the lathe) by super gluing them to another piece of stock. I use industrial grade super glue, clamp together, allow 24 hours to cure and am 'relatively' conservative in my cuts. It might take a little longer than I would like but at least the job gets done. To remove the part from the stock just hit it with the heat gun (not literally lol)
    Dec 2012
    569
    Quote Originally Posted by bob1112 View Post
    you may have to go to the next level of inconvenience and think about drilling and tapping for screws in the back of the part to hold it to a fixture, if there is enough thickness to do that. or adding tabs that you can mount the part with, machining 99% of it, then clamping the part in place on its face while you machine the tabs off
  1. Small part fixture
    By l u k e in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-31-2013, 05:16 PM
  2. Help with multi-part fixture
    By Pharkas in forum MetalWork Discussion
    Last Post: 09-12-2012, 04:07 PM
  3. MM MCX part into INCH based fixture
    By bostosh in forum Mastercam
    Last Post: 02-08-2011, 07:10 PM
  4. Cylindrical part milling fixture
    By umniy2000 in forum MetalWork Discussion
    Last Post: 08-30-2009, 03:48 AM
  5. Any ideas to secure this pcb to a fixture?
    By Binow in forum DIY CNC Router Table Machines
    Last Post: 07-29-2004, 06:15 PM
