588,227 active members*
4,711 visitors online*
    Apr 2007
    11
    Ignoring Feed Speeds
    Having an strange issue. Been using Desk CNC to run a 4 axis foam cutter, which DeskCnc has created a whole CAM system to extract G code with. This works well and makes good code, but for some reason, the created code will not obey feed speeds. No matter what I change it to, nor how drastic, it stays at one extremely slow speed. It feeds in and out at much faster and what I consider regular speeds, but as soon as it does actual cutting of an object, it slows to molassas. I use only one feed speed in the beginning of the code, so I'm not sure what's telling it to slow down. Has anyone else had a similar problem? Anyone know a way around this?
    Dec 2007
    30
    hi,xichanceix
    have you checked out the machine velocities in the deskcnc software?make sure that's in a correct settings, and also see what number you have entered in the "contouring" parameters,
    it's located at the bottom of the machine velocities window,i have the number 1 entered for smooth aceleration, if you enter 2 or 0 it will change the speed profile it's possible your problem, also verify the "speed range", i use my router on 40-125000sps,now switch to "axes set up" and verify "max vel (sps)" parameters increase the value of them and try. when i was setting up my software i had similar problem and i found it on the "machine" tab, where the parameters of "break arcs into lines" it was in the default mode and the machine was too slow when countoring, then i've entered the new number 0.00020 and it did a lot better motions,i don't know if this will help you but if it does,let me know, thanks.
  1. Need Help on Figuring Speeds
    By mgandy02 in forum DIY CNC Router Table Machines
    Last Post: 01-12-2007, 04:59 PM
  2. Small end mills feed speeds for 1mm steel
    By paulr4 in forum DIY CNC Router Table Machines
    Last Post: 08-13-2006, 01:29 PM
  3. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
  4. New table running! Q about bit feed speeds and bit durability
    By psantangeli in forum DIY CNC Router Table Machines
    Last Post: 03-07-2006, 04:52 AM
  5. geko 340 speeds
    By broncosis in forum Gecko Drives
    Last Post: 07-30-2004, 12:08 AM
