587,762 active members*
3,293 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Im ordering a 1325 CNC to made doors (In Africa)
Hybrid View
    Aug 2020
    3
    Hi all,
    Im a 100% NEWBEE in CNC.
    Im a retired Telecoms Engineer from the UK, and just to pass the time and enjoy a hobby !! I am buying a 1325 CNC machine to "play around " with.
    I can easily make all the electronics and understand them, BUT CNC carving is LATIN for me !
    I would like to engrave DOORS (double sided engravure) {Sorry I passed 38 years in France and mix up English and French}
    The wood here in African RED wood which is fairly hard, i can get it in 4cm 5cm and 6cm thick.
    I think a V bit will be able to grave some nice paterns , BUT how DEEP shoud i go ??? I think a main front door to be secure should have some wood left on it to resist agressions... And If i grave each side on lets say a 4cm door how much thickness will be left ????
    The doors will be made up with 5-7 planks in red wood, glued together and around 2.8mt long. Surfaced, then carved .. so What thickness should the wood be to have a good looking carving each side AND leave some wood on there .....
    Could someone help me with this question..
    Thank all
    DAVID
    Mar 2008
    216
    Re: Im ordering a 1325 CNC to made doors (In Africa)
    Quote Originally Posted by netchip View Post
    Hi all,
    Thank all
    DAVID
    You are posting in a totally wrong discussion group. This group is *specific* to the Tormach metal cutting milling machines, which you apparently do not have (there is no Tormach 1325, let alone made for woodworking).
  1. Kosovo customers visiting and ordering of 1325 ATC CNC Router
    By elephantcnc in forum Blue Elephant CNC
    Last Post: 04-07-2020, 07:08 AM
  2. Replies: 0
    Last Post: 03-26-2020, 03:04 AM
  3. Customer Feedback 1325 4 axis Wooden doors Engraving Machine
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 10-11-2019, 10:37 AM
  4. Sample made by Sudiao 1325 CNC Router
    By sellcnc in forum Tormach Personal CNC Mill
    Last Post: 03-23-2015, 07:06 AM
  5. Ordering industrial made AC servo drives
    By Xerxes in forum Servo Motors / Drives
    Last Post: 07-07-2008, 04:16 AM
