Re: imperfect circles
I would certainly love to see greater pinion contact and spacing out the rack wouldn't bother me at all, assuming I'm not giving up any rigidity. Just putting a 1/8" flat washer between the rack and frame is something I've thought about doing, may still do that but I'd want to make sure they were all the exact same thickness. I'd have to check the bolt length but there's probably enough thread to do 1/8" without any problem. Putting a full length strip between the rack and frame would be better but I don't have access to a surface grinder to ensure the strip is a constant thickness.
David
Romans 3:23
Etsy shop opened 12/1/17 - CurlyWoodShop
