603,988 active members*
3,200 visitors online*
Results 1 to 4 of 4
    Oct 2005
    37
    Good evening
    We’ve got a used Integrex 300 with a controller 640 Pro. Unfortunately I have only worked with matrix until now.
    We’d like to transfer our programs to the 640th. But the controller has only floppy or PCIMA adaptor. I inserted a PCIMA adaptor with CF card. When I tried to choose the folder on the card where the programs should be imported, the 640th said something about a wrong format.
    I tried out the card with FAT16 and FAT32 but without success.
    When I connect the card to Matrix with a USB adaptor, everything works.
    Does anybody have an idea?
    Jasper
    May 2006
    173
    Hello
    Check the E/A parameters. Maybe something is incorrectly set there.
    Robert
    Hello
    Did you try to format the card at the machine?
    There must be a menu item “format”, then confirm it with “”-9999”!
    Greetings
    Trompetenschlumpf
    Oct 2005
    37
    Thanks a lot for your help! But the card just seems to be incompatible.
    It worked with another one.
    Regards, Jasper
