587,798 active members*
3,356 visitors online*
IndustryArena Forum > CAM Software > UG NX > Import stp file in NX
    Jan 2008
    63
    Hello,
    Never thought about this one before.
    I have a assembly file exported from Inventor as a stp file. In normal course if i import that file into NX it will create all the parts and maintains the assembly structure as well.
    But all the new NX parts are created using default NX part template.
    What i want is to configure is that the new parts use my standard part template(seedpart) instead of standard NX part template.
    I am using Nx4.
    Regards
    Ananth Kulkarni
    THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
    Oct 2007
    41
    Ananth,
    If you look in the install directory for NX, there are 2 folders (STEP203UG, STEP214UG)
    Look for NX part files in these folders (i.e. step214ugnullnx50_in.prt)
    These are the 'seed' parts that get used when doing a translation.
    If you replace the appropriate part with your own template part, it will use it as the seed part.
    I would recommend backing up (rename to .bak) the supplied part before replacing it.
    Be Well
    "Of course, that's just my opinion. I could be wrong!"
    T Briggs (CAM dude) - Siemens PLM Software
    Jan 2008
    63
    Thanks Brewmeister it works
    Ananth Kulkarni
  1. import .SAT file
    By Tinmuk in forum Surfcam
    Last Post: 07-23-2007, 10:28 PM
  2. DXF-file import problem
    By stmahe in forum Dolphin CAD/CAM
    Last Post: 04-12-2007, 04:28 PM
  3. file import(again)
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2005, 01:57 PM
  4. file import
    Last Post: 06-07-2005, 08:01 AM
  5. file import
    By motomitch1 in forum OneCNC
    Last Post: 03-25-2005, 04:08 AM
