588,570 active members*
8,379 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > importing control point curves from rhino
    Mar 2007
    7
    I have been trying to import control point curves from Rhino and can only get a series of connecting lines. Can I get the lines to be interpreted as curves so my parts don't end up with facets instead of smooth curves. Can the cad drawings be done in such a way as to allow bobcad to import the shapes with a smooth perimeter curves. How do you import complex geometry that doesn't have straight lines and get it to cut without facets?
    Aug 2003
    449
    You may want to try exploding the curves into simple entities for import/export. This will allow you more control over the faceting of the geometry. When you import a Spline or Poly Arc the system interpolates it into simple entities on its own, if it is already converted to simple entities, then you shouldn't have any issues with the import.
    Regards
  1. Importing from Rhino to Mach
    By gregrnel in forum Mach Mill
    Last Post: 03-05-2009, 06:41 AM
  2. How to control the starting point of a pocket
    By journeyonline in forum BobCad-Cam
    Last Post: 08-14-2008, 03:15 AM
  3. importing Mastercam art files in Rhino
    By sdantonio in forum Mastercam
    Last Post: 04-02-2007, 03:07 PM
  4. Replies: 0
    Last Post: 11-13-2006, 08:55 AM
