Re: In need of Linear stages
Originally Posted by
Vivek9093
Hello,
We are in urgent need 4 of the motorized systems which we will be using to create a biaxial compression testing device.All 4 parts will be placed in a horizontal setup.The mass of each part will be around 20kg.(steel)
The horizontal thrust force we will be needing is 1KN and the travel distance would be around 50mm.This is a quasi static test, so speed is not an issue.We are willing to compromise on the resolution as well.We contacted a few companies which are selling the linear stages for around 3000$ each which is beyond our budget,given that we are in need of 4 of these.
Could anyone suggest any companies where I could find these linear stages at a reasonable price.
I have also attached the 3D view of the final setup,which needs to be moved in respective directions(towards each other for compression).
Any suggestion will be very helpful.
Thanks,
Vivek.
Vivek,
Have you tried Bell Everman?
Bell-Everman, Motion Control Technologies
Mike Everman is a fellow CNCZoner, he may cut you a deal.
Welcome to the Zone,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
