586,067 active members*
5,011 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Inappropriate Haas "Alarm 430 File Unexpected End of Input"
    Jul 2013
    3
    I do have the beginning and end "%", which is what Haas suggests the problem is. I've omitted some special characters from notes, omitted spaces in case I had one where I shouldn't, etc. I keep getting this alarm when I try to load from USB. Any suggestions? Thanks!
    O08940(NT 89402)
    G0G90G80G40G17
    (DIAL IN FIXTURE HOLE AS G54X0Y0)
    (BLACK SURFACE AS G54Z0)
    (G55 G56 PICKED UP BY PROBE)
    G10L2P1X-27.62Y-12.82Z7.80
    (T25 PROBE)
    (T1 1” KEY CUTTER)
    (T2 #4 CD)
    (T3 .516 D)
    (T4 .257 D)
    (T5 1/4” RUF, SET .27)
    (T6 1/4” FIN)
    T25M6
    G0G90G54G43H25X-2.7Y0Z5.
    Z1.T2
    G65P9832
    G65P9810Z.33F10.
    G65P9811X-3.05F10.
    #101=#185
    G0Z1.
    X2.7Y0
    G65P9810Z.33F10.
    G65P9811X3.05F10.
    #102=#185
    G0Z1.
    #5241=.5*[#101+#102]
    X1.2Y-2.7
    G65P9810Z.33F10.
    G65P9811Y-3.05F10.
    #101=#186
    G0Z1.
    X1.2Y2.7
    G65P9810Z.33F10.
    G65P9811Y3.05F10.
    #102=#186
    G0Z1.
    #5242=.5*[#101+#102]
    X1.5Y-2.
    G65P9810Z.1F10.
    G65P9811Z0F10.
    #101=#187
    G0Z1.
    #5243=#101
    G0Z2.
    X3.6Y0
    G65P9810Z1.5F10.
    G65P9811Z1.4F10.
    #101=#187
    G0Z1.
    #5443=#101
    G0Z2.
    X3.Y0
    G65P9810Z1.F20.
    G65P9811X3.4F10.
    #5241=#185
    G0Z2.
    X4.Y3.3
    G65P9810Z1.F20.
    G65P9811Y3.F10.
    #101=#186
    G0Z2.
    X4.Y-3.3
    G65P9810Z1.F20.
    G65P9811Y-3.F10.
    #102=#186
    G0Z2.
    #5442=.5*[#101+#102]
    G65P9833
    G0Z5.M9
    M1
    T2M6
    G0G90G54G43H2X0Y0M3S917Z5.
    Z.1T3
    G73R.08Z-.14Q.02F1.2
    G0Z5.M9
    M6T3
    M1
    G0G90G54G43H3X0Y0M3S222Z5.
    Z.1T1
    G73R.08Z-.24Q.02F1.2
    G0Z5.M9
    M6T1
    M0
    (ADD BOLT)
    M0
    G0G90G55G43H1X1.3Y1.5M3S114Z5.
    Z.6T2
    G1Z.005F20.
    X1.6Y-1.8F1.1
    G0Z5.M9
    M1
    M6T2
    G0G90G55G43H2X2.25Y2.25M3S917Z5.
    Z.1T4
    G73R.02Z-.2Q.02F1.2
    X-2.25
    Y-2.25
    X2.25
    X2.Y0
    G0Z5.M9
    M6T4
    M1
    G0G90G55G43H4X2.25Y2.25M3S458Z5.
    Z.1T5
    G81R.02Z-.2F1.2
    X-2.25
    Y-2.25
    X2.25
    X2.Y0
    G0Z5.M9
    M6T5
    M1
    G0G90G55G43H5X2.Y0M3S4580Z5.
    Z.1T6D5
    G1Z-.1F9.
    G41X2.36
    Y1.692,R.25
    X1.692Y2.36,R.25
    X-1.692,R.25
    X-2.36Y1.692,R.25
    Y-1.692,R.25
    X-1.692Y-2.36,R.25
    X1.692,R.25
    X2.36Y-1.692,R.25
    Y.02
    G40X2.
    G0Z2.
    G56X.6Y2.2
    Z.1
    G1Z-.2
    G41Y2.435
    X.28
    Y-2.435
    X.6
    G40Y-2.
    G0Z5.M9
    M6T6
    M1
    G0G90G55G43H6X2.Y0M3S4580Z5.
    Z.1T25D6
    G1Z-.1F18.
    G41X2.36
    Y1.692,R.25
    X1.692Y2.36,R.25
    X-1.692,R.25
    X-2.36Y1.692,R.25
    Y-1.692,R.25
    X-1.692Y-2.36,R.25
    X1.692,R.25
    X2.36Y-1.692,R.25
    Y.02
    G40X2.
    G0Z2.
    G56X.6Y2.2
    Z.1
    G1Z-.2
    G41Y2.435
    X.28
    Y-2.435
    X.6
    G40Y-2.
    G0Z5.M9
    G91G28Y0Z0
    M6
    M30
    Aug 2019
    Something similar has happened to me and putting a space/EOB after each “%” fixed it.
    Just curious: does your program work not having G02/G03 when circular interpolating and also with the commas (,)?
    Hope you figure out your issue.
  1. "Test this axis" - unexpected result
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 03-29-2022, 10:26 AM
  2. Replies: 8
    Last Post: 04-02-2017, 12:25 PM
  3. Replies: 1
    Last Post: 09-28-2016, 04:18 AM
  4. Alarm :" input que low"
    By bull_frank in forum Cincinnati CNC
    Last Post: 09-06-2015, 02:51 PM
  5. Macro alarm "009 ILLEGAL ADDRESS INPUT"
    By theemudracer in forum Fanuc
    Last Post: 12-26-2006, 04:57 PM
