603,794 active members*
5,560 visitors online*
Results 1 to 9 of 9
    May 2006
    214
    Inches and mm
    Hi everyone -
    How do I set up my drawing to get inches an mm. when I use dimensions. My print needs to show both (do not ask me why).
    Anybody????
    Thank you
    George
    Nov 2005
    1468
    What design package are you using please?
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jan 2004
    3154
    After you open a new drawing
    Go to "tools" - "options" - "document properties"
    turn on "dual dimensions" and make sure primary units are set to inches and secondary units are set to mm.
    Pressing F1 = HELP (this is a very good and easy to use feature)
    www.integratedmechanical.ca
    Aug 2006
    246
    I would assume that you are using Solidworks since you posted this in the Solidworks forum. Go to the "Tools" menu and click "Options". A window will pop up (hopefully) Click on the 'Document Properties" tab and you should see it. It's the first option on that page under the heading "Dimensioning Standard"
    :cheers:
    I don't know much about anything but I know a little about everything....
    May 2006
    214
    Thank you guys.
    I got it.
    George
    Apr 2005
    903
    Metric-Inch defaults
    I know how to change the unit dimensions in SW, but it's annoying to have to set it whenever I start a new part.
    Is there a way to set up program defaults to user preferences?
    Jan 2004
    3154
    Make a part template for metric parts instead of using whatever template you are currently using (I assume you are using the default SW template).
    open a new part, change the document settings to whatever you wish ie. metric units. save it as a part template.
    Apr 2005
    903
    So, saving the part as a template will save the settings in that file as a user preference setting?
    Jan 2004
    3154
    Don't actually make a part, just change the settings in the blank part document and save it as a part template.
    I have all my templates saved on my server and have SW file locations point to that file. You can save your template in the default SW location if you wish.
    I could type pages of instructions but it is all in the help file anyway.
    I hate typing...man
  1. Metric mm or Imperial inches? Please help.
    By alexccmeister in forum Benchtop Machines
    Last Post: 02-22-2007, 03:19 AM
  2. inches per minute
    By planescott in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2006, 01:29 AM
  3. 6 inches = 6/10's movement???
    By CRFultz in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2005, 12:41 AM
  4. Inches / Minute in Aluminum
    By rcazwillis in forum MetalWork Discussion
    Last Post: 04-07-2005, 01:15 AM
  5. Mach2, pulses per sec, inches per min
    By Bloy2004 in forum Mach Software (ArtSoft software)
    Last Post: 11-16-2004, 01:56 PM
