603,946 active members*
2,033 visitors online*
Results 1 to 13 of 13
    Sep 2006
    11
    Question Increasing Memory in Fanuc 18?
    I was talking to the Okuma tech today on my Okuma 511V with Fanuc 18 controller about the memory, we have like 30k on it, and he said it's just a parameter setting to increase it. Does anyone know what parameter it is? Thanks!
    Justin
    Dec 2003
    24260
    Some options require a hardware addition also, but the 18 is P9921:
    Bit#0 = 640m
    Bit#1 = 320m
    Bit#2 = 160m
    Bit#3 = 80m
    Bit#4 = 40m
    Al.
    Albert E.
    Sep 2006
    11
    Quote Originally Posted by Al_The_Man View Post
    Bit#0 = 640m
    Bit#1 = 320m
    Bit#2 = 160m
    Bit#3 = 80m
    Bit#4 = 40m
    Al.
    Thanks I will try that tomorrow, is there any risk involved in changing it? As to losing parameters or anything?
    Dec 2003
    24260
    Quote Originally Posted by jdocmm View Post
    Not normally, you may get an error message if the physical memory is not present, I would try one size at a time, starting with the low one, see what the parameter is now.
    Always make sure you have the parameters copied anyway.
    Al.
    Albert E.
    Sep 2006
    11
    Al.
    Hey Al, I went ahead and saved my parameters, and my P9921 to begin with was
    0 1 0 0 1 0 0 0
    so i tried doing
    0 1 0 0 0 1 0 0
    thinking that was correct, but that took me to 0 k memory, should I be changing the # in bit 6? please advise, thanks
    Dec 2003
    24260
    Normally only one of the memory bits is set, the only thing I can think is you do not have the physical memory present, the option only enables it, you may want to contact Tulip Memory, they sell expansions for Fanuc mem and may be able to advise you if you need hardware as well.
    Al.
    Albert E.
    Feb 2007
    38
    I'm pretty sure (90%) that going from 80m to 160m will require at least an ~0351 module. The ~0352 module is the biggest module fanuc has for the 18 series. I don't think they (fanuc) will sell you one unless it's already installed in your control.
    Feb 2007
    592
    Question Registerable programs?
    What is the Max # of registerable programs a Fanuc 18 can support?
    Currently I see Ooooo (MDI) + 63 for a total of 64.
    Is this it? or can this number get pumped up too?
    Dec 2003
    24260
    9923 bit #5 = 125 registerable programs.
    Al.
    Albert E.
    Feb 2007
    592
    Thanks Al!
    Next time I purge the machine I will give those settings a try.
    Machine is a 1998 Mori Seiki SV50B with the MSC-518 labeled Fanuc 18 (pre i model).
    Nov 2005
    219
    we just upgraded our 18-I to 1000 part prgs and 2560m
    it required hardware.
    cost about 3500.00 I think
    Jon
    Dec 2006
    84
    deleted
    Sep 2006
    11
    Al.
    Well it appears we need to buy the expansion module to get it to work, thank you for the info though!
  1. Fanuc 15m Memory
    By rugbyal in forum Fanuc
    Last Post: 03-04-2008, 01:15 AM
  2. Fanuc 0 M memory
    By matic in forum Fanuc
    Last Post: 05-27-2007, 06:33 PM
  3. Memory problems fanuc 3tc
    By R.thayer in forum Fanuc
    Last Post: 01-29-2007, 04:27 PM
  4. Fanuc Bubble memory
    By golfengraver in forum Fanuc
    Last Post: 11-13-2006, 05:16 PM
  5. memory issues on fanuc 11m
    By cncwhiz in forum Fanuc
    Last Post: 10-10-2005, 12:12 AM
