587,357 active members*
3,646 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe > Index pulses in diags but machturn doesn't see it anywhere else
Results 1 to 4 of 4
    Apr 2003
    302
    Index pulses in diags but machturn doesn't see it anywhere else. I am using the latest lockdown version and an old reliable machine. I can't calibrate spindle or thread.
    May 2003
    233
    i have the same problem just rebuilt my lathe got it running today
    loaded newest lockdown version works in diag. not on manual or auto
    it did work on this lathe last year i can not remember what version of
    machine 3 i used but i am using same index sensor i set spindle real
    slow and watch index light blink in diag. screen thanks
    Jul 2003
    1754
    I think you have to tell mach the spindle is on by m3 or m4.... (it's new)
    sam
    May 2003
    233
    yes you are right you also have to tell it you have a sindle relay even
    if you do not thanks all works now thanks kinda thought but tried the
    m3 thing but did not work till i faked the relay
  1. MachTurn problems and questions
    By Bertho in forum Mach Lathe
    Last Post: 09-22-2009, 07:57 AM
  2. Max pulses and IPM
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-05-2008, 06:11 PM
  3. Pulses irregular ?
    By tmead in forum Machines running Mach Software
    Last Post: 10-08-2008, 05:01 PM
  4. Accumulated pulses?
    By MattTheNoob in forum Gecko Drives
    Last Post: 09-15-2008, 02:59 AM
  5. Step Pulses per second?
    By thielert in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-06-2003, 07:35 PM
