603,959 active members*
1,843 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Indexable tools.. what applications?
    Jan 2009
    484
    I got the Littlemachineshop tooling set for the 8-12 with the indexable toolholders. The description is this:
    The set of indexable turning tools includes 5 tools (TAR, TAL, TBR, TBL, TE), inserts, a wrench, and extra screws.
    I get that you want the sweep to be away from the cut and that has worked well.
    Which one do you use for facing operations? Does it just follow the same rules.. sweep away from the cutting direction? Is there another tool I should be using entirely?
    Also... any reason you can't use the straight-on holder for threading purposes? (Assuming you use a pointed insert without a rounded nose.)
    Last dumb question... I see that the sweep angles have one that ends at *90, I can see where that would leave a nice shoulder. Is there any advatage to useing the one that goes past *90 for other operations?
    Dec 2008
    445
    Quote Originally Posted by TroyO View Post
    I use the left hand tool for facing.
    You certainly don't need a "pointed" tool with no radius to cut threads. Have a look at thread form specs, you'll see there are allowances for the bottom of the thread. Sharp pointed tools take more work to cut, and dull quicker.
  1. Applications Engineer
    By Philm in forum Employment Opportunity
    Last Post: 04-17-2008, 01:37 AM
  2. CNC for medical applications
    By mfahad016 in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2006, 08:49 PM
  3. Mach 3 capabilities & applications
    By howling60 in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2006, 01:28 AM
  4. Replies: 0
    Last Post: 02-05-2006, 09:49 AM
  5. EDM Applications Engineers Needed
    By kimb in forum Employment Opportunity
    Last Post: 10-06-2005, 05:28 PM
