603,321 active members*
3,605 visitors online*
Page 1 of 12 12311
Results 1 to 20 of 305
Hybrid View
    Sep 2005
    229
    Induction furnace
    Hello!
    Im thinking of building a induction furnace of about 2,5 kW! The electronics seem to be very simple to build! With a vacuum pump and a good chamber it should be possible to cheaply and cleanly melt just about every kind of metal or to make perfectly homogenuos alloys
    http://www.richieburnett.co.uk/indheat.html
    How would you solve the pouring in the closed chamber? I was thinking of using a solenoid to "pull the plug" in the bottom of the crucible. It would take much space to tilt the crucible and harder to get the pour in the right place
    What kind of refractory should i use to be able to melt higher temperature metals? How high vacuum would i need? Will i need flux? What material should i use for crucible?
    /Jay
    Aug 2004
    2849
    I'm sure there is a reason why commercial furnaces don't use "pull the plug" on their crucibles....could be differences in thermal expansion.
    Sep 2005
    229
    I was thinking about a cone as the plug with a spring who push it down in the hole with the same draft angle.. Something like this! The spring should keep it tight
    /Jay
    Mar 2004
    847
    Just out of curiosity, what would you make the 'plug and rod' out of to keep it from melting?
    EDIT: Nevermind, read better and answered my own question. :idea:
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Sep 2005
    229
    Well the same material as the crucible i guess... Perhaps graphite or some kind of ceramic I dont want it to react with the metal! Would graphite change the properties?
    /Jay
    Mar 2004
    847
    Quote Originally Posted by JBV
    /Jay
    So you would be planning on having someone custom make the crucible?
    I looked at the cost of graphite crucibles once, they ain't cheap!
    I guess I don't see why the hold/plug custom crucible would even be needed? Judging from the page you linked - it would seem that you would just make your coil large enough to put the crucible inside and use hooks/tongs to get the crucible out of the center off the coil (after you shut it off, I would assume).
    Now that I think about it, you should be able to embed the coil in the wall of a self-made furnace... :idea:
    I don't know, I just like to keep things ASAP - As Simple As Possible.
    Sep 2005
    229
    I'm planning on doing all melting and casting under vacuum in a closed chamber to avoid oxidation, so i have to be able to do the casting by "remote"
    A ceramic crucible (and plug) should be very easy to make... Just build a form for it and then burn it in a kiln.
    Simple solutions is working... But takes away the fun in building and designing And is often not optimal This is what i'm thinking of... I guess it could be a problem with sealing. :P I guess it would be nice to be able to measure temperature! Can you use a IR thermometer trough glass?
    Apr 2004
    105
    There are lots of simple ways to protect the melt from oxidization other than a vacuum. As far as bottom tapping goes many have tried different methods of plugging and sealing without much success. Even the smallest leak that can't be stopped can ruin you furnace. Depending on what you are melting home made crucibles are fraught with danger, a bit like juggling eggs.
    If you want to see a very successful home made induction furnace check out –http://home.iprimus.com.au/cmckeown/...on_furnace.htm
    This furnace primarily melts cast iron. The results are an extremely high grade of metal.
    Sep 2005
    229
    Yep i have seen that one Very cool! Well if i build the electronics its easy to try different coils and configurations... I guess i would start with something simpler like that! Just to get started anyway
    I've been aprofessional metalcaster for close to 25 years witha degree in metallurgy. Oxidation is least of your concerns when processing steel. Depending upon the composition, nitrogen is the biggest culprit.
    You also use different molding materials for steel. Petrobond won't do. Kiln dried ceramic makes great mold and casting, all of that with it's own process restraints and problems.
    You don't want to use graphite crucibles with steel, the molten metal dissolves the graphite in the crucible and you end up with a stainer.
    You have to have steel in the 3050 degree F range to pour it and it looses heat really fast!!!! All the prep work and you end up with a mis run casting.
    Commercial vacuum induction furnaces, especially with aerospace castigns and alloys, have the preheated ceramic mold on top of the induction furnace, at the proper time teh whole unit is inverted and the mold filled.
    Dec 2003
    24260
    Were there any schematics posted somewhere for the one shown in the link?
    It's OK I did'nt look hard enough (chair)
    Al.
    Albert E.
    Jun 2005
    24
    Have there been any development in this field lateley??
    I am in the process of gathering information on a furnace that could be used for melting Al and possibly for making some Al/Mg alloys.
    Ideally, I want to use electricity as the energy source, and have already made a ill-conceived attempt at making a resistive heater, but I can't find a suitable castable refractory, so I resorted to fireplace-brics and leca, loosely fitted in a large steel bowl, and using nicrothal wires coiled up as springs, and fitted in slots carved in the bricks.
    The result was a big spike in the electric bill, and alot of red-hot leca and fire bricks...
    The Al I managed to melt, ate it's way through the capped steel pipe crucible, and generally made a big mess..
    I'm pondering a new design, using a red clay crusible and furnace liner/heat wire holder and using mineral whool for insulation.
    While browsing the net, I found out about induction heating, and started to seriously consider this as an alternative route.
    Al is a very conductive material and also it's not magnetic, and I would guess that it would be pretty hard to develop enough heat to melt it.
    How would clay stand up to the thermal fluctuations that one could expect from a furnace like this?
    Just hours ago, I exploded a small square of hardened glass by ignoring the stresses caused by uneven heating.
    I made a small coil from my heating wire, and placed it on the glass, and placed a piece of Al inside...
    The al melted, and solidified into a blob on the glass...
    I removed the glob, and put the glass aside to cool down.
    After maybe 5 minutes, it exploded, and sprayed small glass cubes all over the place...
    Would clay behave in a similar manner, or is it more flexible?
    Nov 2005
    1468
    I know I asked this before, but it may have seemed like a flippant question and wasn't meant to be, but if I was to stick a hypothermia victim in a big enough induction furnace would the effect on the iron in the blood heat the core temperature and save their life?
    Most research seems to state that increasing the body temperature in these cases is difficult due to cold blood flowing from the extremities back to the core causing, well, basicaly death.
    Immediately attempt to rewarm the victims body core. If available, place the person in a bath of hot water at a temperature of 105 to 110 degrees. It is important that the victim's arms and legs be kept out of the water to prevent "after-drop". After-drop occurs when the cold blood from the limbs is forced back into the body resulting in further lowering of the core temperature. After-drop can be fatal.
    So... if you stuck a hypothermia victim in a big eoungh induction thingy... would it heat them uniformly? if it could why isn't it used then?
    (Oh I can understand NOT microwaving such cases: microwaves would heat everything in the body, probably boiling your eyeballs, but surely only heating the blood would be well, good?)
    I love deadlines- I like the whooshing sound they make as they fly by.
    Nov 2006
    592
    Induction heating works by magnetically inducing an electrical current into a conductive material. The resistance to that current, multiplied by the square of the current, is what causes heating to take place. It's an undesirable side effect in power transmission and transformers; to get any useful effect, you need ridiculously high currents and usually, high frequencies. As particle size becomes smaller, the particles become invisible to the magnetic field, so higher frequencies are necessary. When you get to molecular particle size, you are already working in the microwave and higher frequency range anyway. In which case all heating is primarily confined close to the surface.
    Particle heating in adhesives has been tried, with spotty results. Ridiculously high frequencies and power levels are necessary, and uneven heating is usually the result, with some not heating at all while other areas burn.
    So no, it won't work on rust molecules in your blood. At least, not in the form generally recognized as induction heating. Microwaves work by heating water molecules, and some modified approach along those lines might work, but it's probably too dangerous. Why don't you get an industrial microwave and do testing on fresh cadavers? LOL.
    Probably infrared heating through conduction is the only method the human body can withstand. Meaning, a hot bath.
    --97T--
    Jul 2005
    12177
    Quote Originally Posted by ImanCarrot View Post
    I know I asked this before, but it may have seemed like a flippant question and wasn't meant to be, but if I was to stick a hypothermia victim in a big enough induction furnace would the effect on the iron in the blood heat the core temperature and save their life?..
    I touched on this in Post #119. The effect, as 97T points out is not on the iron in the blood but on all the conductive fluids in your system.
    Jan 2008
    Cool Induction heater page
    I have been interested in induction heating for the better part of a decade, and have given in and bought several commercial units. The gist of it is, if it's good, it's expensive (like the Magneforce 1500R I bought), and if they are cheap they usually don't work well or don't last long.
    I don;t know what the linking rules are here, but if you do a search for Neon John Induction Heater you'll find a very cool page. Unlike all the other blog pages, here you can actually find plans, pcb layouts and ExpressPCB files, and loads of USEFUL information.
    If you are on a budget, this is a great place to get some traction on your project....
    FYI
    G
  17. #17
    May 2009
    40
    Old photos,
    The sample for debugging, 66 кГц, 2 kw
    The first melting, 13 minutes (cold start)
    The subsequent meltings approximately 4 minutes
    Defect of casting from for the cold molds
    The experiment purpose not copper fusion.
    The experiment purpose: research of characteristics of the furnace
  18. #18
    Nov 2005
    10
    Hello All,
    I am new to posting to this forum. However, I have been a scientific lampworker for nearly ten years now. If you wish to make an electric furnace for the purpose of melting metals then you should contact these companies (they are both owned by Amaco): Amaco and the Brickyard.
    This link is for the electric elements. The ones you all probably will want to use are the metal enameling replacement elements. I have one of these kilns, produced in 1948, and it reaches temperatures in excess of 2500 degrees C on 120VAC! The kiln has two elements of 500 watts each, connected in series for the high temp setting and in parallel for low (or the other way round, I cannot remember). A pyrometer and thermocouple show absolute temperature.
    http://www.amaco.com/jsps/grouphome1...0Amaco%20Kilns
    The elements can simply be stapled to kiln brick, which is fairly cheep when not precut, in a zig-zag or cyclic fashion.
    For kiln brick for any style of refractory, contact the Brickyard http://www.brickyardceramics.com/
    For the making of high temperature crucibles as described to me by a dear friend:
    1. Choose a suitable clay (some experimentation may be necessary for your exact application, e.g., type of metal).
    2. Form some of the clay into thin pieces (about 4mm thick), dry, and bisk fire in a kiln, or your furnace, to a cone of less than that of the final firing, see later steps. Large underground kilns have been used for centuries for this purpose, heated by wood or charcoal.
    3. Break the bisk into small particles, fine grind with a hammer, or some other means.
    4. Combine up to about 50% bisk back into the original clay, this should be as homogeneous as possible.
    5. Form into a crucible shape, either with a wheel, or core-formed. I would not recommend hand-built techniques, as it should be a single piece of material, not joined parts.
    6. Dry, and fire the second time at a higher temperature.
    Notes: After the firing process is heated to the desired temperature, always cool the stoneware inside whatever it was fired in, and as slowly as possible till completely cool. The addition of bisk clays provides for more strength and higher temperature capabilities compared to that without.
    The crucibles can be made into any size and thickness. As small comercially available crucibles are relatively cheap, however, the larger ones are a bit expensive.
    Hope this helps...
  19. #19
    May 2006
    9
    Just throwing out an idea here.....
    An Argon 'flood' would probably be alot easier than vacuum. Argon is heavier than air, and tends to pool in low places (this is a serious safety concern in welding, use extreme caution when TIG welding in a confined space :drowning: ).
    All equipment and refills are readily available at welding supply places. You could rig a system to keep a slow steady stream flowing into the furnace and simply displace everything but the inert Argon. Figuring out a way to pour might be tricky, but the flipping method mention earlier sounds like a winner. :cheers:
  20. #20
    Jul 2005
    66
    Um, since AL is non-ferrous, I don't think you can use inductive heating on it, since inductive heating relies on eddy currents from the magnetic field..since AL is not magnetic, it won't work - only for iron and steel...
    -niko
Page 1 of 12 12311
  1. 12.5 kW Induction Furnace
    By meanu in forum Casting Metals
    Last Post: 04-24-2013, 07:19 AM
  2. My Furnace
    By vertek in forum Casting Metals
    Last Post: 02-28-2008, 07:15 AM
  3. induction furnace
    By vallabesan in forum CNC Machine Related Electronics
    Last Post: 12-13-2007, 04:19 AM
  4. Arc Furnace
    By aggie_67 in forum Casting Metals
    Last Post: 08-28-2007, 06:27 AM
  5. DIY Oil Furnace
    Last Post: 09-24-2006, 02:35 PM
