603,371 active members*
3,828 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Inductors with Rutex Drives
Results 1 to 5 of 5
    Feb 2005
    35
    I am in the processs of converting and Anilam Crusader to Mach 2 control.
    I have 4 Rutex R90H, Relay board, and Mother board. I am using the original 140VDC to power the motor. My question is, would it be alright to leave the inductors between th drives and motors or should I get rid of them? Thanks.
    Dec 2003
    24260
    I assume you have DC servo's, they are probabally low inductance motors hence the inductors, I generally leave them in place when retrofitting as it makes it a bit easier on the drives.
    Al
    Albert E.
    Feb 2005
    35
    Yes, the motors are 120 volt dc. I am going to continue to use the 120v power supply and 8700mf capacitor, but I am going to chang out the motor to these http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
    . Should I continue to use the inductors, and if so should I buy an additional one for the 4th axis or just not use one on it? I should have been more specific on the first post. Thanks
    Dec 2003
    24260
    If you want to be safe, the ideal is to obtain the minimum value that is spec,ed in by the drive manuf. and obtain the inductance value from the motor manuf. to see if they fall within the rating of the amp without using series inductors. I would keep them to go with the new motors, The 4th axis you may have to apply the method I mentioned above.
    Al
    Albert E.
    Oct 2003
    170
    Inductors in motor circuit
    Gentlemen,
    Vladimir has recommended that inductors in the motor circuits be removed, as they can negatively affect the PWM output of the drives.
    Tom Eldredge
  1. 2000 series Rutex drives
    By rutexus in forum Servo Drives
    Last Post: 04-03-2007, 10:00 PM
  2. Help to setup Rutex drives
    By Moondog in forum Servo Drives
    Last Post: 07-12-2004, 10:26 AM
  3. problems with tuning of Rutex drives
    By FrankdB in forum Servo Drives
    Last Post: 06-21-2004, 09:16 AM
  4. Rutex Drives
    By mikburts in forum Servo Drives
    Last Post: 05-01-2004, 01:55 PM
  5. Rutex Drives
    Last Post: 04-10-2004, 01:16 PM
