Can anyone give me more information on the type of laser I need to cut acrylic sheets about 5mm thick so that I get a clear finish on the cut. Preferably I want to build the table and the laser. Any information will be appreciated.
cut acrylic sheets about 5mm thick , i think you can use 80w laser cutting machine, can you tell me the width and length of your acrylic sheets, then i can suguess you a type of machine in our factory, i you would like.
The average size I would need to cut would be about 500mmX500mm but I was thinking of a table size of 1000mm X 1000mm so I would be able to mutiple pieces at once. Also would I would like to find out if a laser cutter would be able to make small holes as well (approx 1.5mm).I would be cutting 3mm / 4mm and 5mm acrylic.
if cut for that size, i think you can use DC-G1290 size:
Technical Parameters
Laser Power 80W
Supply Voltage 220V
Max width 1250mmx900mm
Engraving/Cutting speed 1000mm/s
Locating Precision <0.01mm
Min shaping character Character:3×3mm Letter::2×2mm
Operating temperature 5°C -26°C
Resolution 0.015mm
Control Configuration DSP
Data transfer Interface USB
System Environment WINDOWS2000/ WINDOWS XP
Cooling Way Water Cooling and Protection System
Graphic file format BMP,GIF,PCX,TGA,PLT,CDR,DXF,AI
Cutting thickness 0 – 20mm
Color Separation Yes
Cuts off the water supply the protection Yes
Slope Engraving Yes,360° slope can be designed easily
Net Weight 200kg
Machine dimension 1700x1200x1150(mm)
hope this information is useful for you, i am the munufacturer of laser machine
Kevin
E-mail: [email protected]
price?
We also have the laser cutter can do good job for acrylic cutter. If you like, I can send you some vedio on the laser cutting on the acrylic 3mm-8mm.
my yahoo email:
[email protected]
We also have the laser cutter 80w can do good job for acrylic cutting. If you like, I can send you some vedio on the laser cutting on the acrylic 3mm-8mm.
my yahoo email:
[email protected]
hi,
i am unable to contact on your mail Mr laserengraver on your following email address "[email protected]"
I am looking for laser cutting machine for acrylic, kindly send me your product specification and price list and let me send demo video for laser cutting process for acrylic.
35 watts will cut that. My Epilog 40watt will cut 1/4" acrylic no problem.
Larry in South Carolina
Dear Sir,
i have write private email to you, hope you have received it , and hope will contact me from my contact as below, and please tell me yur contact email, i will send my parameter to you, and give you a price.
Your faithfully,
Kevin Zhang.
Tel:0086-13563522963 Fax:0086-635-8511101
Skype:lcshkevin MSN: [email protected]
E-mail: [email protected] Website: www.lcshenhui.com
www.shenhuilaser.en.alibaba.com
Factory Add: Changjiang Road ,Liaocheng Economic Development
District, Shandong Prov. , China .
Kevin
Dear Sir:
I happened to see your message in CNC zone. I am from Jinan G.Weike Science&Technology Co.,LTD. We are a manufacturer for laser engraving machines, laser marking machines, CNC routers and cutting plotters.
Our machine can cut the acrylic from 5mm-20mm. We have many models for your selection, LG 500 LG 900 LC6090 and LC1280 etc.
Pls visit our website and check the specifications. (http://jinweike.diytrade.com)
If you want to cut, you had better choose LC6090 LC 1280. They are 80w laser power and better for cutting.
We can also produce the machine according to your request, if you need a
special size. We can meet your demand. :rainfro:
Look forward to hearing from you soon and working with you in the future!
Best regards
Linda
Hi Bread O:
We are the manufacturer for laser engraving/cutting machines. Our machine LC6090 LC1280 can are better for cutting. They are 80w laser tube.
Our machine LG500 and LG 900 are 60w laser power, they can also cut acrylic to 5 mm.
Pls visit our website and check our products. www.wklaser.com
You can also send me email and know more about our prodcuts.
[email protected]
35 - 40 watts will cut the Acrylic. 80 watt will just cut faster. It depends on how much you are willing to pay for the extra speed.
I am not completely useless.......I can always serve as a BAD example.
You are right. 40w laser can also cut acrylic, big power will cut faster and have good cutting effect. You can also choose LG 3040, it can do that . And this desktop is very popular and cheap.
Best regards
We have more than 20 6090SE sold here and some customers bought this machine for cutting acrylic you can get my contact from www.rabbitlaser.com you can call me if you are in US
Frank-rabbitlaser
Lasers from China are ok, but:
1. Laser life - 1000 hours. In real life she works 3 week on maxim power
8 hours/day. Laser tube is cheap (150$ - 80W).
2.Focal length of final lens 2 inch - for a decent cut of 20 mm of acrilic need focal length of 7 inch.
3. Reflectors for light path are from Ge coated with Au. On 80 w laser first reflector is changed every 2 weeks.
cristian,
Where can you get 80W laser tube at $150?
Frank
we have excellent laser cutting engraving machine. It can be used for cutting acrylic, wood, paper, etc. More info can be found in Laser Engravers, Laser Cutters, Laser Dieboard Cutter, CNC Router, Laser Marking: FALC or contact [email protected]
