587,990 active members*
4,639 visitors online*
Results 1 to 8 of 8
    Jun 2008
    262
    Injection mold machine retrofit?
    Has anybody out there done this?
    Perhaps a nightmare for a novice considering stroke sensors and the like....
    i build the braces that keep american teeth straight......tick tick tick
    Jan 2006
    2985
    If you are a true novice, then I'd say it might be a nightmare. It's not super complicated though. A new PLC would handle all the thinking and then you just have switches, sensors, relays, contactors, solenoid valves, temperature controllers, etc.
    Dec 2003
    24220
    Posted in the Camsoft forum, so I assume your are considering this?
    Should be a piece of cake for Galil?
    Al.
    Albert E.
    Jun 2008
    262
    I've done a 3 axis mill with camsoft. how does the control see the speed, strokes and pressure feedback? Has it been done with camsoft?
    We're thinking about a machine with way outdated and unsupported control. It's a BOY ! (it's a brand of machine)
    Anyway, my maintenance expert at Boy said it was Very risky to buy a machine they only made for 4 years circa 1991, and indeed he mentioned retrofitting with a PLC.
    I think that would be tough.... thoughts?
    Jun 2008
    262
    I didn't find a forum devoted to PLC's here. Should there be, I don't know.
    Apr 2003
    332
    nelZ,
    Yes, it has been done. We can also supply a cleaned up set of files for both the logic that was used and operator interface, that already works, so you wouldn't have to do this from scratch. If you do decide to continue on, let the person here know you're already a customer. You'll receive a discount. Also this is a low cost non-CNC application that we've already done, so you won't have to work your way around any CNC features in the software or pay for CNC software. Typically the version called the Graphical Operator Interface software is only $247 to existing customers.
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
    Dec 2003
    24220
    Quote Originally Posted by nelZ View Post
    There are quite a few forums now to plow through, it can always be posted in the Electronics or software forums.
    Al.
    Albert E.
    Mar 2004
    1543
    Quote Originally Posted by camsoft View Post
    nelZ,
    ... Typically the version called the Graphical Operator Interface software is only $247 to existing customers.
    !!! MAN I would have done my packing line with Camsoft for that price. Twice the power of a PLC and easier to program.
    I'd use linear encoders for any position sensing. USdigital has some really inexpensive encoder strips.
    Have you counted up how many analog inputs you need? If you're under eight any Galil card would do ya. 8-16 would need a 5 axis card. or, maybe Camsoft has another way to read analog inputs. if you don't run out of inputs, do your temp. controllers right in Camsoft.
    20 years ago, I did molding machines, mostly working with parts pickers to take the part right out of the mold. Coordinating the picker PLC with the mold machine PLC was a real pain in the arse.
    Karl
  1. Basic knowledge of injection mold and injection molding-4
    By vulcanmold in forum News Announcements
    Last Post: 11-10-2010, 05:23 PM
  2. Replies: 0
    Last Post: 11-10-2010, 05:10 PM
  3. Basic knowledge of injection mold and injection molding-1
    Last Post: 11-10-2010, 05:03 PM
  4. Replies: 0
  5. (4) Small plastic parts needed. 3D print, Injection mold, machine?
    By diyengineer in forum Employment Opportunity
    Last Post: 08-20-2010, 09:47 PM
