603,959 active members*
2,348 visitors online*
    Mar 2004
    370
    insalling spindle encoder in 1J head
    Hey,
    I just figured out how to install a spindle encoder on a Bridgeport 1J head. I made a web page at
    http://pico-systems.com/bridge_spindle.html
    with some pictures and description. Now I can do rigid tapping on it!
    Jon
    May 2008
    132
    John,
    I recently did the same thing on my J-head. Those sensors work very well, just watch out for vibration caused by the magnet pulling on the teeth, you don't want the bracket to fracture inside the gear housing.
    I epoxied my sensor in a plastic housing that mounts in a recess I milled with a wood router. Since I am using Mach3, I had to divide the sensor output by 81 with a little Atmel uP to get the 1 PPR that mach needs. Will have to think about quadatrue for the future.
    Craig
    Some pictures
    http://picasaweb.google.com/cschafft...20847739556546
    http://picasaweb.google.com/cschafft...03095682315170
    http://picasaweb.google.com/cschafft...73728040270130
  1. What is the best spindle encoder?
    By CATCH22 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2009, 02:06 AM
  2. Vari-speed head spindle encoder
    By RP Designs in forum Vertical Mill, Lathe Project Log
    Last Post: 06-22-2009, 07:23 PM
  3. Spindle encoder
    By Mark Hockett in forum Fadal
    Last Post: 03-17-2008, 09:27 PM
  4. SX3 Spindle/Head temps
    By extrapilot in forum Syil Products
    Last Post: 11-11-2007, 07:32 AM
  5. spindle encoder
    By heilcnc in forum LinuxCNC (formerly EMC2)
    Last Post: 09-10-2007, 03:12 PM
