603,834 active members*
2,777 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Install floppys for Okuma with BP7A110A-ENG OSP-U100
Results 1 to 4 of 4
    May 2016
    16
    Hello all,
    Looking if someone could kindly share Install floppy images for Okuma MC-V4020 using OSP-U10M.
    Someone was messing with the machine due to tool alarms, and now it do not pass from boot screen and it fails at CPU alarm.
    - Have checked the fiber cables with a fiber tester and all it are ok and plugged to their correct ports TX/RX as indicated at the cables labels.
    - Have pulled the NC Rack cards (not the memory cards) and reseated it, battery voltage is ok.
    - The UCMB+F have the RUN led light but the other cards does not.
    - It looks to me the SCSI hard disk also do not spin although it receives 5V.
    - Found the INSTALL switch at "1" position so suspect maybe the machine system was altered someway.
    Turned the switch back to "0" position but the machine go to SBER error red light.
    SBP 7-A V1. 10-A (ENG)
    1-1 CPU-ALARM BUS ERROR (SYSTE MBUS)
    BUS ERROR STATUS (SBER, SBPAR, CYO, 0, PRT, DIA, LOP, ECC) = 80
    SSW=074D ACCESS ADDRESS=E4080080
    OPERATING SYSTEM PROGRAM V4.08-B
    OKUMA 2002. 7. 5
    SBP MONITOR
    I just wondering if a reinstall is need. We have the 9 floppy's but unfortunately only the first one is partially working.
    The seller leaved a note with the 9 floppy's that almost all does not read, and I can confirm that (I'm aware it are not PC readable).
    But the machine does not either read it. Putting the first disk with it boots to a menu with some options like "Install" but as the floppy's are bad, i cannot continue.
    I have a backup of system and user data.
    The install floppy disks we have shows:
    TYPE: CROWN-V
    DATE: 2003-03-12
    P775356
    OSP-U100 SERIES
    SOFT NO: 00356
    MNC CUSTOM FLOPPY 1/9 MNCU77500356-01
    SYSTEM PACKAGE FLOPPY 2/9 SYSF000AENG-008
    MNC PACKAGE FLOPPY 3/9 MNCG334P000-001
    M MACMAN PACK. FLOPPY 4/9 MKMF000AENG-007
    M MOTION A PACK. FLOP 5/9 MOPA000BENG-010
    DNC PACKAGE FLOPPY 6/9 DNCB000AENG-017
    7/9 MTRC202E000-001
    MPLC CUSTOM FLOPPY 8/9 MPCU77500356-01A
    MPLC CUSTOM FLOPPY 9/9 MPCU77500356-01B
    Could someone share a floppy img ot .imz copy of similar machine...?
    Or, could be a card/hardware related issue...?
    Aug 2019
    35
    Hello, I can solve your problem, please pm me.
    Dec 2005
    619
    Re: Install floppys for Okuma with BP7A110A-ENG OSP-U100
    Quote Originally Posted by ospcontrol View Post
    Ask it here, answer it here.
    Mark
    May 2016
    16
    This are the picture of the damaged disks.
    Could someone share a copy...?
  1. Okuma U100 RS232 mystery
    By dafrenchman in forum Okuma
    Last Post: 12-21-2023, 12:13 AM
  2. OKUMA OSP U100 WAY LUBE TIMING LU15 LATHE
    By okuma1984 in forum Machinery Manuals / Brochures
    Last Post: 05-09-2021, 07:01 PM
  3. OSP-U100 Params
    By geeserteg in forum Okuma
    Last Post: 06-07-2018, 07:53 PM
  4. OSP 7030 and U100
    By kurmay in forum Okuma
    Last Post: 01-09-2017, 08:37 AM
  5. Replies: 0
    Last Post: 02-05-2012, 08:06 PM
