I'm getting ready to upgrade my Shopbot PR machine, and I need help to decide between Bishop Wisecarver wheels and rails, or HiWin rails.
The issue that may decide for me is the installation. If HiWin guides have the kind of tolerances they do, will this cause the blocks to bind if my rails are not perfectly parallel or coplaner? How far out can I be before I have binding problems?
To mount the rails, I plan to use tensioned piano wire as a guide, so that a spacer will complete a circuit and light a bulb when I just make contact with the wire. Will that get me close enough to prevent binding?
I'm sure lots of people here have experience installing HiWin or similar rails and bearing blocks. How accurate do I have to be? How do I get this sort of accuracy?
I'm wanting to use the HiWIn, but if they require more precision than my skill and equipment can provide, I'll back up to BWC wheels and rails.
Thanks in advance for your help.
