HI All
Iam a bit new to all is!!
we have an old Bridgeport ser 1 with the TNC145 control.
it orininaly worked ok, it was moved to another position and then not used for some time, perhaps a year.
when we powered it up it comes up with the usual start up screen and asks you travel over the zero points for the X Y & Z axies.
this is as far as you can get, nothing else on the machine will work, you can press the power up and cycle buttons but nothing happens.
I am suspicious that it has lost the paramiters out of the control unit.
does anyone know if this is what happens if the paramiters are lost and what i can do to check.
i rearly only want to use it to get some CNC experience, i know nothing about the machine but we do run a Torchmate CNC profile cuttter so we are not completly new to cnc machines.
I would apriciate an help please
