603,800 active members*
3,467 visitors online*
Results 1 to 5 of 5
    Jan 2007
    311
    Interface card ID help needed
    Does this interface card look familiar to anyone?
Name:	20210504_161605 (Medium).jpg
    Trying to find some wiring diagrams, or really anything at all on it and coming up empty
    Number up one side says 415-0632-901 rev C but other than one dead ebay ad from 2020 there's no mention of it anywere
    (The current mpg connects to it and I'm trying to ad X1, X10, X100 inputs from a new mpg but can't figure where they should go)
    Attachment 463036
    Oct 2017
    30
    Re: Interface card ID help needed
    Okay first lets pretend I have no idea what I am talking about. But, I believe the MPG interface only interprets (receives) the pulses sent from the handwheel. The x1/10/100 function is an electronic manipulation of the pulses generated at the handwheel itself, and the electronics reside entirely within the handwheel. Let's see how long it takes someone to tell me how wrong I am. Meanwhile if I get some time I will review the schematics for my Delta50. I don't have a handwheel and it is older than yours, but it may give some clues as to how the handwheel and control interface.
    Jan 2007
    311
    Thanks.
    The MPG they have is just a selector switch (like the AXIS switch), there's no circuitry inside the pendant.
    On the other machines I've built or repaired (which oddly enough had documentation, the multiplier was always done up on the machine controls.
    I can wire trace everything else but the original ancient pendant didn't the X1 X10 X100, the dynapath should??? be able to deal with it but again, I don't even have a p/n on the stupid thing so I'm flying blind
    Looks like I'll have to try to talk to them
    BTW, the reason I was not going there first is that apparently there is a little friction between the area dynapath authorized service rep
    Thanks again
    M
    Aug 2009
    1573
    [QUOTE=Mooser;2449838]
    Dynapath 2000MU?
    They would need to be wired to the DC I/O Card and modify the PLC program most likely.
    Jan 2007
    311
    Delta 1000, (which really seems rare or something, very little info seems to be out there, their site hardly acknowledges it)
    I know it had to be wired into the i/o but no idea which connections without something to follow or a schematic, there are a handful on their site but nothing matching this one. Was hoping someone might have one that could take a picture.
    I'll have to get the guy to contact them directly, maybe we can fix the weird jog speed at the same time
    M
  1. fault card and drive card for old CMC machine needed
    By 1dumbquestion in forum Want To Buy...Need help!
    Last Post: 10-09-2015, 06:11 PM
  2. Computer interface card needed
    By Maksym in forum Want To Buy...Need help!
    Last Post: 05-22-2012, 08:05 PM
  3. C10 interface card PS
    By Vatorman in forum CNC Machine Related Electronics
    Last Post: 05-29-2011, 04:41 PM
  4. Lpt interface card
    By abbe in forum Open Source Controller Boards
    Last Post: 05-18-2011, 09:38 PM
  5. New Port Interface (Breakout) Card
    By Torchhead in forum News Announcements
    Last Post: 10-27-2006, 09:59 PM
