603,832 active members*
3,882 visitors online*
    Mar 2006
    36
    Interpreting Driver timing
    I am using IM483 drivers (Intelligent Motion System). I found these specs in the user manual in a table named 'Logic Input Timing', but I am not clear how I interpret them for the driver timing settings in EMC.
    (Specification) (Input) (Time)
    Min Pulse Width, Reset, 500nS,
    Min Pulse Width, Step Clock, 75nS,
    Typical Execution Time, Step Clock, 100nS,
    Typical Execution Time, Direction, 100nS,
    Would Step Time be 75nS or 100nS? and Step Space?????? Directin Hold and Setup??????
    Any insight into understanding this data and/or how to determine these settings would be much appreciated.
    Cheers,
    Dan
    Feb 2007
    514
    One of the EMC gurus says
    75ns steplen, 100ns stepspace, 100ns dirspace, probably 100ns dirhold
    I got that like this: steplen=step clock width, stepspace="step execution time", dirsetup and dirhold both="direction execution time"
    That is the fastest timing I've ever seen so if it does not work increase the values and test in the Stepconf.
    If this is ok let me know and I'll add it to the list at wiki...
    John
    Mar 2006
    36
    Thanks Big John T. I'll let you know how those work out once I install EMC.
  1. i want to cut timing pulleys , so help !!
    By max_imum2000 in forum MetalWork Discussion
    Last Post: 08-08-2008, 06:16 PM
  2. THC Timing?
    By Red Earth in forum Waterjet General Topics
    Last Post: 04-16-2007, 04:03 PM
  3. Timing Belts .200 xl
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 03:09 AM
  4. Timing Pulleys
    By h_2_o in forum Benchtop Machines
    Last Post: 02-03-2005, 05:26 AM
  5. Timing Belts
    By chas in forum DIY CNC Router Table Machines
    Last Post: 01-19-2005, 04:03 PM
