587,762 active members*
3,458 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Inventor - making a mold
Results 1 to 7 of 7
    I've spent way to long trying to figure this out....
    I have a complex shape.
    I want to make a mold cavity out of it.
    But if I extrude a box around it, I can't cut it so that the complex shape is removed. The cut Boolean is very restrictive.
    Basically - I can't figure out how to make a mold cavity in Inventor.
    Any suggestions? I'm sure this will be easy once someone lets me in on the secret.
    bgraham111
    www.lightningrobotics.com and www.sallysgeckoranch.com
    Jan 2007
    355
    I can't comment on Inventor, but Cadkey 19 has a boolean difference function that subtracts one solid from another.
    You'll probably have to use a two or four part 'block' to enclose your shape.
    Perform a boolean difference on each of the sections.
    The Cadkey function works 99.9% of the time; some shapes generate an error.
    No idea why.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Apr 2004
    105
    Create a "Derived" component from your model.
    I do this all the time to create core boxes for moulding.
    Basicly does a subtract from your positive model leaving the cavity in a box.
    Should be examples under the help files. Look up derived component.
    Cam
    Feb 2007
    1084
    In some cases, the molded part can't be molded and ejected from a 2 part mold. I'm not a big mold guy, but I have seen molds with what they call "slides" for complex mold cavities such as you've mentioned.
    Hope that helps, sorry I can't be too much more specific, you almost need to talk to an engineer in the mold industry.
    Quote Originally Posted by Me2 View Post
    Cam
    BINGO - that's it. I couldn't find it. It's not like UG, NX, Solidworks, CATIA, etc...
    mc-motorsports: No need for a slide or horn pins. I'm just doing this at home for some poured soap molds. The think that was frustrating me was that I design complex, multi-slide tools at work, for class-A surfaces. I just couldn't do a simple single pull tool at home, only because I use inventor at home.
    I just tried it and it worked like a charm. Just hard to find in the menus if you don't know where to look.
    THANKS EVERYONE!!!!!!!!!!!!!!!!!!!!!!!
    bgraham111
    Mar 2008
    5
    Hey all I been really struggling with getting this derived component to work.
    I have drawn my core and is saved as .ipt
    I have drawn a block as my mould and also saved as .ipt.
    Deriving component just seems to overlay it with no option of subtracting core shape from block.
    i tried playing with .iam but just frustrating myself and am meant to have this cutting yesterday.
    Someone please tell me the proper process.
    Thanking you in advance.
    Mar 2008
    5
    OK sorted it 5 min after posting.
    I wasn't using the derived component surfaces as soon as i did that i could then sculpt the surface from my solid block.
  1. Autodesk Inventor Mold (beta)
    By EL DUKE in forum Autodesk
    Last Post: 05-13-2010, 12:57 AM
  2. Making Mold and Die
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 04-22-2008, 05:49 PM
  3. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
  4. Mold making with Deskcam
    By Jon D in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2007, 10:41 PM
  5. Welcome to the mold making forum.
    By cncadmin in forum Moldmaking
    Last Post: 07-07-2003, 05:22 PM
