I ordered some 2184's and HIP4080A IC's today needing to get a bipolar design together. Ideally the 4080 is nice as it is a full Hbridge driver in one IC, with a few extrenal charge pump parts needed. Ok so that brings up a big issue, charge pumps. I have heard that unless the inputs are constantly being pulsed at a minimum of a few hudred hertz that they lose charge, a nd turn of the output until the cap is recharged. The mystery is this, if you are already PWMing a stepper that is not moving, this should be no problem, the cap is constantly being charged based on the PWM freq. But, what if the motor is turning at a speed that and the sense has not kicked in the comp, then what? Is the frequency of the Step inputs enough to work. Every design I see for these type drivers is that there is just a cap and diode, no explanation as to how and when to setup some advanced means to charge the cap, say for example some method to keep the cap charged if the PWM from the processor was not kicking in.
If anyone could make this ramble above make sense for me that would be great. It isn entirely possible that the thing may just work as is. If there is another suggestion for hbridge driver I am open to that as well.
