Originally Posted by
leeK9
the shape follows a function....its not really as arc or radius that can be meausred.....
i basically have 360 points that i can traverse through on a G01 and take the middle section that is left with a circular pocket or something
Well that may be true but when you establish a min max error (ie + - .005) I am betting that the pocket can be described as several arcs with tangential connections.
I have made prototypes for wankle motors in the very distant past and NONE of the drawings I received were functions.
My bet is there is an allowable deviation from the equation (deviation from perfect) and that is what you need to determine.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
